E40D - OEM Trans gasket....rubber or cork?
#31
on
Questions:
1. What is in that package (fitting with 2 hoses/wires coming out of fitting)? Does is it have something to do with the trans, cooler, trans temp gauge?
2. Since you have no sending unit in your port, are you running a trans temp gauge (added after pic was taken)?
3. Is trans sending unit an electric sending unit installed at test port with a wire that is run to a gauge installed in cab somewhere?
4. The trans cooler you mention is one I have that I purchased new about 10 years ago. I posted a thread earlier today about this cooler. Why are you running this cooler if your temps are under 190?
Thanks
Thanks
2.it's a generic pic i sourced off google images to explain where the test port is.
3.i do run electric trans temp gauges in both trucks,yes.
4.i run this cooler w/ t-stat so that my trans temps do remain at or close to ideal trans temps,year round while plowing,towing,hauling.
i actually didn't buy either one.the trans shop who rebuilt my trans in chip truck installed it.the same setup came in log truck when i bought it.
#32
#33
on
https://www.ford-trucks.com/forums/1...-for-e40d.html
it's the blue piece you see in your package with the hose fittings/clamps.
transmissioncoolers.us: Tru-Cool Remote External bypass
#34
I didn't realize it was a t-stat. I just assumed it was a manifold for line distribution. Since it does not snow where I live, and only gets down to about mid 30's, I'm wondering if I need this blue t-stat?
I should probably start with a trans temp gauge, as you suggested, and go from there.
Decisions, decisions.....
#35
#36
I am a little concerned about the ground clearance for my stock height 2WD truck if install the 4WD deeper trans pan.
#37
If you are addressing the question to me my E4OD with a deep pan is on a 1994 F53. Yes the F53 is a 4X2 classed as a truck.
The F53 is a very large class "A" RV with a lot of ground clearance and it came with the deeper 4X4 pan from the factory in Mexico. All 1997 and older F53 Fords were made in Mexico.
#38
Jesse4
07-08-2016 04:50 PM
lupin398
11-17-2011 03:14 PM
99f350sd
06-07-2006 10:47 PM
