CREWCAB ONLY
Old 11-22-2014, 02:08 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by F350-CC-LB-DRW-4X4
Wow, yes! The truck did have an aluminum brush guard.
The fuel doors on mine are 6-1/4" × 6-3/4".
Currently only stickers in jam are the nameplate, one in red writing about ambulances, and one about 4x4 roll-over and handling characteristics.
Then that is a factory dually bed out on your truck. Another way to tell for certain is the fenders. Is there an flat flip to screw wheel well trim to or is there no lip?
Originally Posted by Pappawheely
Brad, Where did you get the spacers? I am thinking of widening my rear track.
ARROWCRAFT. All billet steel and hub centric. $220
Wheelspacer.com sell the EXACT spacer for $370
I am running the 2" ones in the rear of both my truck to even out the track
  #332
Old 11-22-2014, 02:41 PM
Pappawheely's Avatar
Pappawheely
Pappawheely is offline
Thanks. I am putting a uhaul box on mine and would like a little more width. I have a dually axle too but don't know which one is wider hub face to hub face. I thought I read where the dually axle is narrower. I want to stick with SRW. I know I would have to change the spring pads, the axle is from a C&C.
  #333
Old 11-22-2014, 04:58 PM
Diesel_Brad
Dually PICKUP axle is 6" wider than the SRW. and a cab-n-chassis axle is...... IIRC 3" wider than SRW BUT the perches are 4" narrower due to the narrower frame on the cab-n-chassis. If you have a Dually Pickup axle, there would be no doubt that is how I would go about it
  #334
Old 11-22-2014, 07:12 PM
Pappawheely
I only have the C&C axle. Spacers seem like a better choice.
  #335
Old 11-22-2014, 07:55 PM
Diesel_Brad
How much do you have to lengthen the frame to put the Uhaul body on, 2 feet?
  #336
Old 11-22-2014, 08:18 PM
Pappawheely
Yes, The box floor is 10 feet. I will build a section that extends the frame and holds the rear winch. The subframe that will attach the box to the chassis will go the full length of the frame & help tie the new section in.
  #337
Old 11-22-2014, 09:13 PM
Fastback460's Avatar
Fastback460
Fastback460 is offline
That is a really nice truck, I'm thinking about using the same colors when I repaint mine.
  #338
Old 11-22-2014, 09:42 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
If you notice in the photo, I have rubber bushings on both sides of the heim to keep it parallel.
Ah, I think I do, are they tapered?
Does that mean you did have a roll issue that you resolved or an issue you knew beforehand and addressed it during your installation?
I am thinking of going to a heim front end and am looking at a different layout that puts the drag link from the pitman arm connecting to the top of the drag link or the knuckle end.
Thanks for responding!
  #339
Old 11-23-2014, 06:12 AM
Diesel_Brad
So you think you are just going to lengthen the BACK of the frame? Not cut and section in a 2' piece?
  #340
Old 11-23-2014, 09:42 AM
Pappawheely
Yes, That's the plan.
  #341
Old 11-23-2014, 09:58 AM
Diesel_Brad
That is going to be A Lot of weight hanging off the tail
  #342
Old 11-23-2014, 10:36 AM
Pappawheely
No, not really. All the heavy items like the water tank, (actually that's about it) are mounted between the axles. When I haul a motorcycle it will be inside sitting right over the rear axle. The back of the box will be empty and the rear extension will be tied into the length of the frame. The box is made of FRP and aluminum and it's only 24 inches. I don't plan on towing anything with much tongue weight.
  #343
Old 11-23-2014, 11:31 AM
tomahawk869's Avatar
tomahawk869
tomahawk869 is offline
nice vintage trucks
  #344
Old 12-22-2014, 02:43 AM
Insane 1's Avatar
Insane 1
Insane 1 is offline
My 96.. I built it in 05 it's not a Centurion.
Here is how it is most of the time with a car behind it....
  #345
Old 12-22-2014, 07:28 AM
Fastback460
I usually don't like lowered trucks, but that is cool.
And I like that grill, did you make that yourself? If not, where did you get it?
Quick Reply: CREWCAB ONLY
