Help ID this truck
Received 4,134 Likes
on
I'm not finding anything exactly to match yours. The C70 is obviously a C700. The fourth digit is the engine, "O" is for a Cummins NH-250, but the book says that's in 62/63 and your fifth digit "9" says its a 1959. The sixth digit is production plant but I find no "0" or "O" code. The last five digits are the unique number for your truck. Stu
This VIN is garbled, some of the codes make no sense, please look closely at it again / 11 digit VIN:
The first 3 digits is the serial number: C70 = C700 Tilt Cab.
The 4th digit is a letter. This is the engine code, it's probably either a C (292 2V) or a D (292 4V).
The 5th digit is a number, denotes the year: 7 = 1957; 8 = 1958; 9 = 1959; 0 = 1960.
The 6th digit is a letter, decodes to the specific assembly plant that the truck was assembled at.
Last 5 digits are numbers, decode to the Numerical Sequence of Assembly for the specific year that the truck was assembled.
DATE: 23B = February 23 (1959?).
Only 1958/59/60 C Series came with dual head lamps. 1957 & 1961/86 C Series came with single head lamps.
Pic: Example of Rating Plate, on a C Series, it's riveted to the inside of the glove box door.
