98 F150 oil in coolant
There needs to be reasonable assurance it is the cooler coil first.
Is the oil deposits reddish or blackish?
The coil is put in the end cap and sealed with fittings before is it put on the core.
Either replace the radiator or disconnect and use an Aux cooler.
The difference will be from a cold start the trans will take somewhat longer to heat up before allowing OD to function until the fluid temperature reaches about 98 degrees.
Good luck.
Good luck.
