Have you ever seen or heard of this? EXPLODING RADIATOR with Pics
Old 04-19-2014, 01:27 AM
Mako Innovations's Avatar
Mako Innovations
Mako Innovations is offline
This was interesting.
https://www.ford-trucks.com/forums/1...l#post14275079
I have never heard of this or seen it. I don't understand why a hose didn't fail first....
Old 04-19-2014, 05:28 AM
EricJ's Avatar
EricJ
EricJ is offline
I can tell you why it happened, I've seen it several times. When they built that radiator, it has a tank design called a bucket tank, it had a pan saldered tothe top of the bottom half of the tank, then the top tank is soldered to that pan. Some half-assed radiator shop threw the pan away when they recored it, without the pan it has no strength and every time it builds up a little pressure it weakens the solder joint, until it can no longer hold. If you are going to have that recored, you'll need to find the pan, or have a GOOD radiator guy make some connectors for between the tanks.
Old 04-19-2014, 08:26 AM
jamusfam's Avatar
jamusfam
jamusfam is offline
Wow first time for me
Old 04-19-2014, 11:28 AM
jamusfam's Avatar
jamusfam
jamusfam is offline
Good thing I replaced my hoses
Old 04-19-2014, 12:12 PM
Mako Innovations
Hmmm interesting, either way that thing is going on my garage wall and I will get an aluminum rad, cheaper than a re-core anyway.
Old 04-19-2014, 03:09 PM
VocaTexas's Avatar
VocaTexas
VocaTexas is offline
Yep, been there myself. Years ago I was driving a '79 F-600 tanker truck loaded with gasoline. Running down the highway about 60 mph when there was a loud 'boom' and the windshield turned green. Mine didn't come apart exactly where yours did; it blew the entire top tank off the radiator.
Old 04-19-2014, 09:06 PM
rockittsled's Avatar
rockittsled
rockittsled is offline
Originally Posted by VocaTexas
..... there was a loud 'boom' and the windshield turned green.
and the underpants turned brown
Old 04-19-2014, 09:27 PM
Mako Innovations
Actually it didn't surprise me as much as shorting out the battery leads earlier.
Old 04-19-2014, 11:01 PM
VocaTexas's Avatar
VocaTexas
As Bill Cosby said, first you say it, then you do it.
Old 04-19-2014, 11:18 PM
78 PEB's Avatar
78 PEB
78 PEB is offline
I have never seen it happen, but would suspect a radiator cap that didn't vent like it was supposed to.
Old 04-20-2014, 08:49 AM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
I saw it happen when a friend didn't have enough ethylene glycol in the system. It got cold and the core froze. When the motor got warm, the tank lifted off half the cores.
Luckily when I did the same thing on my Chevy last year, the top hose just popped off.
cajunsuperduty
07-10-2011 07:02 PM
Innovative Detailing
11-20-2006 11:10 AM
51dueller
07-02-2005 09:57 AM
Stavid
Aerostar
04-12-2005 08:27 PM
dongc1
07-18-2004 05:27 AM
Quick Reply: Have you ever seen or heard of this? EXPLODING RADIATOR with Pics
