Has anyone taken out 1948-52 rad support upper bar?
The condenser on the front of the radiator I have won't mount on the rad support they way it is because of the bar on the rad support. Has anyone removed the bar at the top of the radiator or modified it? How did you modify it if you did?
Any help is appreciated.
I just had this discussion a couple of weeks ago with Vintage Air. They recommended that I use a condenser that fits below the cross bar. The cross bar is part of the support structure. The condenser does not have to cover the entire front core of the radiator to work properly. The Vintage Air part number that they recommended for my 48 was 03260-VUC. Using the universal brackets that come with the condenser it mounted up quite nicely.
DowneyB
09-06-2016 09:24 PM
Jeff and Nicolle
12-22-2010 11:10 PM
jrcsez
16
08-17-2003 09:54 AM
