crane cams 444232 valve springs
Hey there, just picked up a crane cams 444232 cam and lifter kit for a rebuild i'm doing on a 1989 f250 351w.
The cam came with a sheet that says what spring rate is required, but I cant find what the stock valve spring rates are on these.
So, will the stock valve springs work with this cam or not? It's not that aggressive so I would assume it would. If not, what springs do ya'll recommend?
The specs that crane gave me are as follows...
closed- 107 lbs @ 1.700"
open- 248 lbs @ 1.260"
Or 1 45/64 (not sure what this one means)
Thank You for any insight
My two cents: always upgrade the springs to the desired springs. you can always swap springs with the heads on the motor with an air compressor and a bung that threads into the spark plug hole and connects to the air line. One of those constantly running compressors is not recommended, but a nail gun compressor will work fine.... If you run the stock springs and notice float then you have to replace the springs with stiffer springs.
I'm having some difficulty finding a set of springs that are the specs listed. I assume they don't have to be exactly the same.
How about these? Crane Cams 36308-1 Crane Cams Valve Springs & Retainer Kits - Free Shipping on All Orders @ JEGS
Are new retainers required or just a good idea?
If any of you have experience with a particular spring, throw in you 2 cents.
Thank you
Thank you
on
Yeah that should do it, notice the open rating is at 1.15" while the recommended spec in your fist post is at 1.26", so if you were to work backwords these springs might generate 280-290lbs at 1.26". Also note that the Crane 444232 won't quite generate 0.500" lift even with 1.7 rockers so your springs will never get compressed past 1.2".
ok I have that Crane Cam 444232 in a new build 351W so this really has my attention.
Here is some article's I found.
The Straight Scoop on ZDDP (Zinc) Additives | Blog | Bar's Leaks & Rislone - Premium Automotive Chemicals
ZDDPlus | Maintain proper ZDDP levels in your engine
Valvoline.com > FAQs > Motor Oil Car FAQs > Racing Oil
Red Line Synthetic Oil - Motor Oil - Engine Oil Break-In Additive
http://en.wikipedia.org/wiki/Zinc_dithiophosphate
Synthetic Oil | ZDDP
Ask Mobil 1 Archive - ZDDP
crescentwrencher
06-11-2008 08:17 PM
fordbeast_80
10-15-2004 03:34 PM
