T170FT(RTS) manual trans
Old 03-23-2014, 10:20 AM
raven3's Avatar
raven3
raven3 is offline
Found a 4 speed OD, aluminum case, T170(RTS) manual transmission in a 1982 F150 351W V8 with tower shift.
Believe this transmission was only available in 1984-1985 F150/F250 models.
Was this transmission common for the era?
Is this transmission considered rare?
Are rebuild parts expensive and difficult to locate?
How would it compare to the 4 speed T170F(RUG) OD top loader style manual transmission used in 1978-1984 F100/F150 models?
Old 03-23-2014, 02:24 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
I don't know how it would compare to the other tranny, but it's considered weak compared to the granny 4 speeds. But it does have overdrive which can be important for fuel consumption. I have also heard complaints about the gears being spread too far apart, which drops the engine rpm too much sometimes.
We see a few on here that have problems and need repair, I am not sure how hard it is to find parts for it.
Old 04-30-2020, 07:33 AM
Patrick Allen's Avatar
Patrick Allen
Patrick Allen is offline
I recently bought a 87 F-150 V8 5L, and I'm looking for a good rebuild kit for its manual trans (with synchro's). Do yall think you could help a newbie out? Nearly drove myself crazy trying to find one myself.
Old 04-30-2020, 07:50 AM
Franklin2's Avatar
Franklin2
What transmission do you have? I see you posted in a 4 speed overdrive thread. Are you sure that is what you have?
Old 04-30-2020, 08:28 AM
Patrick Allen
From what I've found it's a T170ft
Old 04-30-2020, 08:51 AM
Franklin2's Avatar
Franklin2
Old 04-30-2020, 09:09 AM
Patrick Allen
Tried both, T.P.D.'s servers are down (I've tried it) and Drivetrain leads me down a rabbit hole that I can't figure out.
Old 04-30-2020, 10:26 AM
Patrick Allen
For those looking for a rebuild kit for a 80's-87' t170ft/3-speed overdrive google "BK112". "BK112WS" if you want synchro's included.
Side note, Transtar has great costumer service (they also make/sell them)
Old 04-30-2020, 05:30 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,107 Likes on 1,795 Posts
Thanks for the feed back on where you found parts.
I was going to say if you see some parts on a site but not everything you are better off giving them a call.
Thanks again
Dave ----
David Hollenshead
01-19-2019 06:04 AM
shop.keeper
09-26-2009 12:22 PM
Dustincoc
07-11-2008 08:10 AM
ralf
1978 - 1996 Big Bronco
02-26-2007 01:28 PM
muscletruck7379
09-25-2003 12:30 PM
Quick Reply: T170FT(RTS) manual trans
