Transfer Case Full of Fluid
Hello everyone! I have a 1990 F250 4x4 with E4OD. I haven't had the truck very long, but I just realized that 4x4 didn't work. I narrowed it down to the transfer case. When I pulled the old transfer case off it was really, really full of fluid. I would estimate several quarts. I didn't pay much attention to it at the time.
So, I sourced another working transfer case. When I bought it I drained all of the fluid out of it and cleaned it up a bit. I installed it on the truck, reconnected all of the drive shafts, and removed the fill and drain plugs in order to prepare refill it. When I removed the drain plug about a half a quart of fluid came out.
Where in the world did this fluid come from???
I used white Tub & Tile silicone. It's been a good year so far, no leaks(from there, anyway <_< )
Correct, it is just a open housing on the transmission side, you will see a big ol hole. Clean area and install gasket or rtv and you're good to go
RTV is fine, but I prefer the gasket, just my preference though.
I had a hard time finding it local, so I got it here:
Transfer Case to Adapter Gasket 4WD 4 x 4 Ford Borg Warner 1345 1350 1354 1356 | eBay
