Started normal then abrupt stall - no fire
Old 03-12-2014, 11:16 AM
Enduroman's Avatar
Enduroman
Enduroman is offline
Truck has been running great lately. Started up normally this am and while idling after about a minute (maybe a little less) it just quit altogether. Turns over just fine, but won't fire now. Tried long glow plug cycle thinking maybe fuel pump had a hiccup, but still doesn't fire.
Fresh tank of gas in it about 5 miles ago. Water??
Any ideas where to start troubleshooting? Thanks in advance!
Old 03-12-2014, 11:18 AM
JKTex's Avatar
JKTex
JKTex is offline
Typo I hope. Otherwise.........
Old 03-12-2014, 11:30 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is online now
Retired Mod
Me too^^^^
See what your ICP is doing while cranking
Old 03-12-2014, 12:52 PM
Enduroman's Avatar
Enduroman
Ha. Yes, it is diesel in there. :-)
Cranked for 10 seconds and there was no reading on the oil pressure guage on the instrument cluster. That what you mean by checking ICP while cranking?
Old 03-12-2014, 01:24 PM
Toreador_Diesel
Retired Mod
Oil pressure guage on the dash is an idiot light that only looks for +-5 psi.
On your scangauge, here are the codes for it:
Injection Control Pressure
07E0221446
046205140646
3010
003900640000
ICP
PSI
500 psi is required for the engine to start, any less and you're going nowhere.
Old 03-12-2014, 01:42 PM
Enduroman's Avatar
Enduroman
OK thanks. Programming this right now. Is it the same test ...crank for 10 seconds or so??? Want to get it right while I still have battery juice.
Old 03-12-2014, 02:28 PM
Toreador_Diesel
Retired Mod
Yes, make a video as it really helps.
Old 03-12-2014, 02:34 PM
Enduroman's Avatar
Enduroman
Highest that the ICP read on SGII was 241, though I'm reading that the SGII can lag significantly. Temperature is just above freezing here so everything somewhat slow - including me.
Cranking slower after a few seconds leads me to a new very stoopid question...
How do I hook up my 12 volt charger (with 100 amp start function) to the system so that i can help this thing crank and get meaningful readings?
Going to program IPR into the SGII while a wait for a reply. ANything else?
Very much appreciate the help here.
Old 03-12-2014, 02:36 PM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
It's a 12v system, not 24. Just hook it to one battery
Old 03-12-2014, 03:12 PM
Enduroman's Avatar
Enduroman
Told you it was a stupid question.
Batteries too low now and 100amps doesn't appear to be enough. Looks like I ain't moving today.
Tried a video. Not sure if this will work...
Old 03-12-2014, 03:54 PM
Toreador_Diesel
Retired Mod
Charge those batteries up and try again, but if while the batteries were still charged you couldn't get more than 241 ICP PSI, you probably have a bad or failing HPOP or a leak at the discharge tube.
Old 03-13-2014, 01:15 PM
Enduroman's Avatar
Enduroman
A friend/mechanic loaned me the tool and told me to pull the IPR, which he thought was likely stuck.. Check it out.
Old 03-13-2014, 01:28 PM
Toreador_Diesel
Retired Mod
That don't look good...
Chances are if that's messed up, the one below the HPOP resevoir needs some attention too.
You could get away with it, but you could also just replace the IPR and be good.
If it were me and I had the cash, I'd make sure HPO resevoir screen was clear of debris and the o-ring between the discharge tube and HPOP hadn't disintegrated.
Old 03-13-2014, 01:30 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
That looks like doorman gasket material to me, have you replaced the oil cooler in recent past?
Old 03-13-2014, 02:12 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Looks like the Dorman curse has struck again...
Josh
Quick Reply: Started normal then abrupt stall - no fire
