While doing hg's is there anything else I should have done?
What else should I replace while the cab is off? I am going to have a new hpop installed (should i rebuild or replace), and a new #5 inj bc it was throwing a low contribution code. Also, going to install a new up pipe to go along with my egr delete. What else should I replace or have them check? Thanks, dave
What is the "18mm black onyx" on your signature?
Are you doing the cap off or someone else? how much harder than the F-250 cab?
How's the oil filter condition?
If you change #5 injectors, clean the spool and change all O-rings the rest of injectors.
What about water pump, new radiator hoses, belt
How did you ect eot delta's look? I would swap the oil cooler since your in there. If you haven't got the updated turbo oil drain line. Disassemble and clean the turbo. If you have ever wanted a exhaust it is soo nice to swap the downpipe without the cab there. Might want to get the manifold to Y pipe bolts ordered the ones I have messed with were nasty one broke but I wasn't going to put the other three ones back in. Do the blue spring update for the fuel Reg. Check over the water pump well or replace it and the serpentine belt since you will have easy access to it anyway.
if the black onyx is the head gaskets return them and Get oem ford. plus I believe the ford ones come with standpipes and dummy plugs I might be wrong tho. It is an excellent time to check all vacuumm lines and all lines and hoses in general.
mgargiullo
03-21-2016 09:16 AM
aldrowsboy
05-07-2013 06:31 PM
