1996 F-250 7.3 Diesel crank but no start
Have replaced valve cover gaskets, glow plugs, ICP, High pressure control pump, IPR valve, ECM,ICM, Fuel bowl heater and switch and IDM. Still having problems getting to start and then stalls when apply gas. Any suggestions? I also do not have access to any testing equipment.
X2 welcome. You just arrived to the best forum ever. . Made what Bill suggested above. BTW do you have WTS ligth?
^^ what he said^^ Ford or IH only.
How many miles on the truck? How old is the oil and is it full? Have you checked/changed the fuel filter? Is/was it black? Notice anything in the fuel bowl? Any injector work ever done?
As I'm sure you know, that's a lot of parts to be throwing at it to try to fix it. This situation shows that testing equipment will pay for itself. Not trying to bash on you, just saying.
minimum 20 psi cranking and 50-70 idle.
Check this link:
https://www.ford-trucks.com/forums/1...ont-start.html
Check this link:
The IHC/Blue CPS
The part oldbird is referring to is: IHC#1876736C91
In case you were wondering, or didn't know.
It's "the blue CPS" everyone talks about.
This CPS offers an advanced timing, and is reputed to make your truck run quieter, smoother, and increase fuel economy with more accurate injection of fuel.
Price is slightly more than your average parts store. Runs 40$ shipped from Improved Blue CPS for 7.3L Ford Powerstroke Diesel
Fred377pine
11-05-2018 06:58 AM
c_hersh
12-26-2017 07:24 PM
Tony Leverington
02-20-2017 11:25 AM
Az_Green_Machine
22
10-17-2015 02:28 PM
