differences between 53-55 cabs?
No differences in the mounting; that said, if you are putting a slant cab on a 56 chassis you will have some issues with the left running board brackets if you choose to keep the under cab gas tank. The 56 uses a long narrow battery, slant cabs use a more square battery...this means that the battery access plate in the floor on the passenger side is a different shape. Shouldn't be a big deal but it is one area that the two designs are different.
I do not. I'm about to take possession of the chassis and I will soon start ordering the guts (engine, tranny, gas tank, radiator, etc).
I've also started looking for a 1955 f100 that has good cab and doors with no cancer not caring about anything else about the truck (could have no engine, transmission, etc)
papawayne
12-28-2012 06:58 PM
davewave649
05-20-2011 12:15 PM
71mach351
15
10-15-2010 04:53 PM
