ISSPRO EV2 fuel pressure gauge - programming warning light question
Old 02-23-2014, 05:01 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
First time using the software to program the warning light on a ISSPRO EV2 0-100 psi fuel pressure gauge. Software is pretty simple & user friendly, I just can't figure out which gauge type to select :
EV2 Standard Gauge
or the
EV2 Ford w/autoheadlight gauges
Anyone have a clue?
Old 02-23-2014, 05:21 PM
Tugly's Avatar
Tugly
Tugly is offline
We don't have auto-headlights, and I don't remember seeing that one in my list... so I'd try the standard first.
Old 02-23-2014, 07:29 PM
white Buffalo
Originally Posted by Tugly
We don't have auto-headlights, .........
That's the weird thing Rich...my Excursion came with them. I thought it was an aftermarket deal but after ripping it all out each piece had Ford part numbers and all.
I guess if it doesn't work one way I'll try the other.
Old 02-23-2014, 07:33 PM
bigb56's Avatar
bigb56
bigb56 is offline
huh I got factory Autolamp on my 02
Old 02-23-2014, 09:47 PM
Stebs's Avatar
Stebs
Stebs is offline
My 02 Excursion has them as well and I know it was factory...
I haven't installed any extra gauges yet in mine but im curious what the difference between the two options are now...
Old 02-24-2014, 12:59 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Are we simply taking about headlights that turn oh when it's dark? Because that is most definitely a factory option. I have it.
Old 02-24-2014, 05:05 AM
Tugly's Avatar
Tugly
Tugly is offline
OK... it sounds like '02 had auto headlights. My mistake. Now I'm thinking there might be a product out there we haven't seen. The EV2s are a diesel performance gauge, but I fail to understand how auto-headlights have a bearing on the programming of this gauge. Maybe it has something to do with how the backlight is programmed.
Old 02-24-2014, 06:33 AM
white Buffalo
OK....... Maybe it has something to do with how the backlight is programmed.
Exactly what it is- all about the lighting. I'll zip ISSPRO an e-mail.
Old 03-05-2014, 11:02 PM
white Buffalo
Well - ISSPRO's customer service took very good care of me. Since my 2000 Excursion came with the Auto Headlights I had to program the fuel pressure gauge using the
"Ford w/autoheadlight gauges" option in the programming software. Not only did they help me get the fuel pressure gauge lighting straight - they also helped me reprogram the EV2 gauges I purchased 3 years ago so the gauge lighting wasn't so touchy on the dimmer switch.
A+ in my book.....
tjustice
07-23-2012 08:42 PM
Mr. Sandman
01-29-2011 12:33 PM
superduty4x4
07-12-2010 07:06 PM
strokersace
13
03-16-2009 09:46 AM
sean23johnson
13
11-17-2006 05:50 AM
Quick Reply: ISSPRO EV2 fuel pressure gauge - programming warning light question
