fuel pressure gauge?
Old Nov 14, 2006 | 03:47 PM
sean23johnson's Avatar
sean23johnson
i want to install a fuel pressure gauge but i have a few questions. should i get an electric or mecanical one? where is the best and easiest place to hook it up? where did some of you guys but your gauge from? i have all auto meter sport comp gauges. thanks guys.
Old Nov 14, 2006 | 04:06 PM
adambomb's Avatar
adambomb
I have been looking at the Engine Mounted Fuel Pressure Test Gauge from DI. It looks like it is made well and easy to install, both +'s for me. If i go ahead and get the shim kit they sell, i will get this gauge aswell. Sorry to no answer your question, because I don't know the answer to which kind of guage is better .
Old Nov 14, 2006 | 09:29 PM
sean23johnson
bump. anyone else?
Old Nov 14, 2006 | 09:58 PM
John311t's Avatar
John311t
I would assume electric would be safer to run inside the truck. I would not want a mech. gauge running 55+psi to blow up while im driving. Its a fairly expensive gauge.
Old Nov 15, 2006 | 12:56 AM
phatdually1's Avatar
phatdually1
Smile
You can run a mechanical gauge inside the cab as long as you use an isolator which is available separately from Di-Pricol or Isspro and maybe from Auto Meter.
Old Nov 15, 2006 | 10:35 PM
jtharvey's Avatar
jtharvey
Electric is by far the easiest to set up and safest. No tubes or isolaters necessary. There is an empty port on the back of the fuel bowl that you can tap into, that just has a plug in it now. You'll need an adapter for it, since the threads are not 1/8" NPT that the sending unit will be. Check with Pure Diesel Power (a site sponsor) for the gauge and adapter. I got my Autometer fuel pressure gauge from him. Be prepared for a little sticker shock though. The gauge runs around $150 if I remember correctly.
Old Nov 16, 2006 | 12:25 AM
sean23johnson
thanks jharvey, do you by chance know how accurate the electric gauge is? i ask because in the past i have always been told that mecanical is the right way to go. i checked your gallery, did you use all electric gauges?
Old Nov 16, 2006 | 12:47 AM
Tenn01PSD350's Avatar
Tenn01PSD350
As accurate as the money spent in it. A mechanical gauge is always best. The electronic units simply use an isolator to translate the mechanical value to an electronic value. This puts the number in the cab without risk of a fuel catastrophe. I too wonder how accurate they are. If memory serves, JT has an isolator going to an in-cab electrical gauge. BTW, there is no way to know how accurate any gauge is without benchtesting it for calibration or a dyno test.
Old Nov 16, 2006 | 08:36 AM
jtharvey's Avatar
jtharvey
sean, all of my gauges are electric, including the new oil & water gauges, except for my boost gauge - it's mechanical. Like Tenn said, the accuracy of the gauge does depend a lot on the quality of gauge you buy.
Tenn, my fuel pressure gauge is actually a full electric version. The sending unit is placed in the Y-block that replaced my fuel bowl.
Old Nov 16, 2006 | 08:11 PM
cdiddy's Avatar
cdiddy
What is does the shim kit do?
Old Nov 16, 2006 | 10:20 PM
jtharvey's Avatar
jtharvey
It just raises the fuel pressure in the fuel rails that are in the heads, feeding the injectors. Most trucks seem to run better when the pressure is up around 65 psi. Typical stock pressure is about 50-55 psi. Link here to the shim kit:
http://www.diperformance.com/dip.php...cts&product=23
Old Nov 17, 2006 | 12:47 AM
adambomb's Avatar
adambomb
any draw back to upping the fuel pressure?? i have been thinking about doing this mod but am not sure if should? BTW i usually run on b100 or at least some blend of bio diesel.
Old Nov 17, 2006 | 01:24 AM
Fat Diesel's Avatar
Fat Diesel
I've been running 65-70 psi for about 2 years now. I have over 200,000 on my original fuel pump and it's starting to drop a few psi under a slight load and drops like 20-30 psi under extreme load. I'd say do it. I use an adjustable regulated return setup from ITP, but the shims work too.
Here's my setup.
Here's a pic of the T fitting I used to connect the under the hood gauge and also the electric sending unit for my AutoMeter in dash gauge.
Old Nov 17, 2006 | 05:50 AM
dfuser's Avatar
dfuser
Inside the cab electrical is the way to go. Less hassle to install than a mechanical with an issolator.
I have done many of these, and its comes to individual preference. Both read the same. We also offer the engine mount setup with a shim kit for those, like me, that want to setup idle pressure.
ihandy
Sep 14, 2013 06:37 PM
Hutch17
Dec 19, 2012 05:16 AM
johnsjsj
Jul 19, 2007 03:26 PM
exiled
Feb 16, 2007 06:39 PM
