Rev test. Whats it mean
Yesterday I thought I would do this so called rev test and sure enough at 2300-2500 rpm the truck stuttered and smoked like a guy that just got caught cheating on his wife(no I've never cheated on my wife but could imagine). Trucks got 270k miles on it. When I start I up cold it will idle rough for about 10 sec and send out a good shot of blue smoke then just a slight haze of blue for maybe another 5 min. I looked in the fuel bowl last night but I changed the filter and oil about 800 miles ago and I think the oil is still to clean to show up in the fuel bowl if it is leaking. What's the next step. I tried sifting through some other threads and couldn't really find much for answers mostly just dead ends and dropped threads
Sounds like it's time for injector o-rings. Mine did the same thing. I changed them and actually got some power back. They aren't that hard to do, just follow all the steps. You can find out how to pull the injectors in the tech folder.
Also have you done glow plugs recently? Cause it's a good time to do them too. My fuel bowl and filter were clean but I had 3 injectors with chewed up o-rings that were hard. Buy the reliant ones from riff raff (they are the oe replacement) and then drive the truck like you stole it. It will run like new.
Edit:spelling
Edit:spelling
on
1 Post
Yep. Quite a bit worse I think. Hard to tell it's just got a single pipe. It smokes a little blue for about 5-10 minutes. Although it doesn't seem to sputter while going down the road. Mind you the road was white and it was a little tough paying attention to the tailpipe while keeping her straight in 5th gear. Slightly slick today
Yama4fitty
01-20-2017 09:54 PM
DIYMechanic
09-24-2011 06:44 AM
Beachbumcook
06-21-2011 04:26 PM
