No oil pressure
Old 02-18-2014, 10:33 AM
sifton's Avatar
sifton
sifton is offline
No oil pressure
Hi gents, I have an 04 F150 with the 5.4. I don't drive it much, I move it once in a while to clear snow. The last time I fired it up, the display read "check gauges". I looked and there was no oil pressure. How could this just happen all at once? Could something stick or freeze? It was cold here in Manitoba for quite a while. I did notice some ice/frost on inside of oil filler cap. Thanks for any input.
Old 02-18-2014, 10:54 AM
1saxman's Avatar
1saxman
1saxman is offline
Its better to not drive it at all than it is to start it and not drive it for at least ten miles or let it run for 30 minutes to warm up. This is because the water vapor always present in a crankcase condenses into water and has to be burned off by a fully warmed-up engine. If not, it re-freezes in bad places, like the oil pressure sending unit or PVC valve/hoses.
Assuming the engine is running and not knocking, I would take it out and drive it for 20 miles or so, or just poking around an urban area might even be better.
Old 02-18-2014, 10:59 AM
sifton's Avatar
sifton
sifton is offline
Thanks saxman, I am planning to put in shop and let it thaw out and see. I hope it's that easy of a fix.
Old 02-18-2014, 11:06 AM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
If it sits for long periods of time it could accumulate moisture in the oil, which could then possibly freeze.
That's all I could think of. Maybe bring it inside a garage/shop and have a heater blow under the engine for a while and see if it will start up and have oil pressure?
Or could be a bad sensor/gauge. Not sure how that works on these trucks.
Old 02-18-2014, 11:12 AM
sifton's Avatar
sifton
sifton is offline
Thanks falcon- I plan to put in shop and turn up the heat!
Old 02-18-2014, 04:20 PM
ophidia's Avatar
ophidia
ophidia is offline
My wife's Mountaineer has a sticky pressure sending unit, so if it's cold out it says no oil pressure until it warms up a bit or you hit your first solid bump. It's been doing it for 50000 miles now, so I'd imagine if it were more than that it would have grenaded by now. Maybe it's just that.
Old 02-18-2014, 04:53 PM
ojai150's Avatar
ojai150
ojai150 is offline
To be clear , was this a one time thing , or does it still say that ?
All trucks will display that if it fails to start and you let off the key.
Old 02-18-2014, 07:56 PM
sifton's Avatar
sifton
sifton is offline
Had it plugged in since yesterday, and it was close to zero today. Went and started it.....I got oil pressure!! In shop now, time for oil change. Thanks for the input guys.
Old 02-20-2014, 01:57 PM
1saxman's Avatar
1saxman
1saxman is offline
Good idea - obviously water in the oil. That thing needs a hot run!
351Inside
02-06-2011 07:21 PM
wolfrum
Modular V10 (6.8l)
12-29-2008 11:50 AM
Geekboy1990
22
12-21-2005 07:09 PM
Lone_Ranger01
1983 - 2012 Ranger & B-Series
03-06-2005 07:37 PM
Boss50
03-13-2004 10:39 AM
Quick Reply: No oil pressure
