1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2002 F250 5.4L with intermittent misfire
Old 02-10-2014, 03:47 PM
sherry0331's Avatar
sherry0331
sherry0331 is offline
I have a 2002 F250 5.4 L with an intermittent Misfire. A little history on the truck in 2011 I replaced the motor with a Ford long block motor, only the block, I used my electronics, intake, etc, this was brand new from Ford. The truck has a total of over 300K miles. Recently it has developed an intermittent misfire. I have changed all the coils and plugs and the misfire is still present. The codes are showing a misfire in cylinder 3 but could be 4 too. The misfire is intermittent because this morning I changed the plugs and truck ran fine, drove to store and it started missing, turned truck off and started up and ran fine again. It has been doing this off and on for a few weeks.
Any ideas??????
Old 02-10-2014, 03:54 PM
DavidB's Avatar
DavidB
DavidB is offline
Given what you have done and that it is intermittent, my first guess would be an injector is sticking, but I hate to guess. Have you pulled the codes?
Old 02-10-2014, 05:22 PM
sherry0331's Avatar
sherry0331
The code was P0354
Old 02-10-2014, 07:41 PM
street rodder's Avatar
street rodder
street rodder is offline
I bet its still a coil. Either you have a spring in the coil not making with the plug or a weak spring that has been compressed and is kinda short. Pull on the springs to lengthen them back out. ( I solved my problem like this)
Pull the coils on those cylinders and check the springs in the coil.
Make sure they are in good shape, no cracks.
Old 02-10-2014, 07:44 PM
Wolfboro's Avatar
Wolfboro
Wolfboro is offline
P0354 Ignition Coil "D" Primary/Secondary Circuit
There is a possibility of #4 coil is acting up . Sometimes it runs fine when it is cold and starts internally arcing when it gets hot .
Suggestion: Swap #4 coil with #3 and see if the error code moves from P0354 to PO353 . If the error codes moves, then it is an acting COP coil that needs to be replaced .
I suggest either Motocraft COP or (its maker) Standard as a replacement .
Good luck,
Old 02-11-2014, 12:03 PM
sherry0331's Avatar
sherry0331
Update: Took the truck last night be hooked up to actual diagnostic computer. Cylinder 3 is the problem, pinpointed to possible fuel injector, change the injector for cylinder 3 and problem still exists.
Pulled out spark plug in cylinder 3 and the tip is gone....
Any ideas????
Old 02-11-2014, 01:01 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
Originally Posted by sherry0331
Update: Took the truck last night be hooked up to actual diagnostic computer. Cylinder 3 is the problem, pinpointed to possible fuel injector, change the injector for cylinder 3 and problem still exists. Pulled out spark plug in cylinder 3 and the tip is gone.... Any ideas????
How much of the tip? If the electrode is burned up that's not the end of the world. If the little bent piece that stets the gap (name slips my mind) Id be worried it's in the motor.
Old 02-11-2014, 06:26 PM
redford's Avatar
redford
redford is offline
Received 1,597 Likes on 933 Posts
The 5.4L plugs don't have a "little bent piece that stets the gap". They look like this:
A missing electrode tip would indicate a very high combustion chamber temperature. That would point to a lean condition, which would be very possibly caused by a bad injector.
The tip burned off while the injector was bad, so even after you replaced the injector you still have a miss. I think if you replace the spark plug you'll be OK now.
Old 02-11-2014, 06:56 PM
Psyclopse's Avatar
Psyclopse
Psyclopse is offline
Redford- what years are those plugs for? I just bought plugs for my 99 5.4, and they don't look like that. They are Motorcraft SP-479 and DO have the "little bent piece that stets the gap".
Old 02-11-2014, 07:22 PM
redford's Avatar
redford
redford is offline
3V engine, I guess.
Old 02-11-2014, 07:24 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Yup, that is a 3V plug.
Sent from my Telegraph using IB AutoGroup
paoilguy
01-03-2014 11:11 AM
busflyer
Modular V8 (4.6L, 5.4L)
11-19-2013 04:12 PM
tysonbroennle
11-28-2012 06:34 AM
jjlrrw
16
02-13-2008 12:34 PM
fireman649
10-15-2004 06:22 PM
Quick Reply: 2002 F250 5.4L with intermittent misfire
