High Boy / Low Boy ?
Old 02-08-2014, 05:26 PM
BogTroll's Avatar
BogTroll
BogTroll is offline
Been trolling the sight now for a bit and have seen the terms "High Boy" and "Low Boy" used to describe some trucks. Yet I am clueless as to what the difference is. Could someone please throw me a bone as to what makes them unique from one another.
Thanks in advance.
Old 02-08-2014, 05:43 PM
k_brenner's Avatar
k_brenner
k_brenner is offline
A "highboy" refers to a 73-77.5 f250 4x4, where as a "lowboy" refers to the 77.5-79 f250 4x4's. the highboys from the factory actually sit roughly 4 inches higher then the later model f250's. hence the term. Other differences in include 2.5" inch front springs that are mounted to a crossmember in the front of the frame, low pinion front big hub front axles, and divorced transfer cases.
Old 02-08-2014, 05:45 PM
1978f-250's Avatar
1978f-250
1978f-250 is offline
Thanks in advance.
1967 to 1977.5 F-250 4x4 is a Highboy although Ford never used that term. Here's a link:https://www.ford-trucks.com/forums/9...mpilation.html
Old 02-08-2014, 08:21 PM
Westcoast Highboy's Avatar
Westcoast Highboy
Westcoast Highboy is offline
The highboy is simply the most awesome truck Ford ever built
They also only came with 4.10 gears, the fuel tank was located behind the seat and they had a narrower frame that regular ford pick-ups.
Old 02-09-2014, 02:35 AM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
All good info, just go to the link to get it ALL.
Pretty sure you are wrong, the 73-79 front springs are all 3" wide, its the rear that are 2.5.....in the 67-77 range I do believe.
Old 02-09-2014, 05:12 AM
trozei's Avatar
trozei
trozei is offline
Front is 5-6 leafs depending on GVW at 3" wide; rear is 9 leafs at 2 1/4" wide.
Old 02-09-2014, 05:16 AM
77&79F250's Avatar
77&79F250
Yes I agree for the front 5 to 6 leafs 3" for a HB and 2 leafs 3" for a 78/79 lowboy.
2 1/4, 2 1/2.... at least I was close? I was thinking they we not 2 1/2, but was not sure, thanks for the correction.
Old 02-09-2014, 05:18 AM
trozei's Avatar
trozei
trozei is offline
At least we narrowed it down.
2.5" front > 2.5" rear > 2.25" rear.
Problem solving.
Old 02-09-2014, 11:06 AM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Are you sure about that?
Old 02-09-2014, 11:16 AM
1972RedNeck
Or 10 leaves.
Old 02-09-2014, 11:34 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
High Boy: 1967/76 F250 4WD - 1977 F250 4WD before serial number Y20,001 (February 1977).
Front leaf springs: 3" wide, 26" > > eye bolt < < 27"
Rear leaf springs: 2 1/4" wide, 26" > > eye bolt < < 26"
C7TZ-5560-F 6 leaf rear spring standard equipment, C7TZ-5560-G 9 leaf rear spring optional. C9TZ-5588-A single (1) leaf auxillary spring optional for both.
Front driving axle ratios (except 1976/77 Crew Cab): 3.54 & 4.09 / 1976/77 Crew Cab: 4.10.
Old 02-09-2014, 01:36 PM
k_brenner's Avatar
k_brenner
You're right, I was thinking rears...
Old 02-09-2014, 03:53 PM
1972RedNeck
ND, could you have ordered 4.56's or 4.88's?
Old 02-09-2014, 10:42 PM
77&79F250's Avatar
77&79F250
It's all good k_b.....at least we know.
Old 02-10-2014, 01:44 AM
NumberDummy
Neither ratio is listed for front driving axles.
sluggo36
53
08-06-2017 02:47 PM
semperfiob
04-29-2007 07:06 PM
LGbugles
12-27-2006 09:48 PM
jbulson
03-27-2002 12:36 AM
craig_1
01-25-2000 11:09 AM
Quick Reply: High Boy / Low Boy ?
