short blocks
Asheville Engine Rebuilders - Home
A Ford Remand engine will be $15,000 installed without ARP head bolts.
An Asheville long block engine should be no more than $6,500 installed with ARP head bolts and more.
Thus, one can install 2 Asheville engines for less than one Ford remand engine.
As for short blocks, Ashville Engines Short Blocks are $2,995; I do not know what Fords cost but probably double that figure.
I know a mechanic that has installed 10 of these Asheville engines with zero failures to date. They claim to ship 10 or more more engines a month. So they should be good at it by now.
Also consider the defective 6.0 engines that routinely fail at 80,000 or less miles were NEW Ford engines at one point. Do you really believe that Ford is going to be any more competent / caring/ professional with their remand engines than they were with their NEW engines? I do not. After all, if Ford sells another defective engine that last 10 days past the warranty that is just more money in their pocket.
In contrast, the people at Ashville Engines only do Ford Diesel engines. If they were as incompetent as Ford they would have been out of business long ago.
I did talk to Asheville today. Unfortunately, they are 6-9 weeks out for delivery time. I simply don't have that time.
Also believe it or not he put me on hold and tried his ford dealer in Minnesota he uses to price me a short block for quicker service. So he musnt be to worried about the ford one being a problem.
OK,
Ashville Engine Long Block: $4,895 with $490 ARP Head STUDS;
Ford Long Block : $9,550 (Ford dealers quote $15,000 installed)
Ashville Engine Short Block: $2,995
Ford Short Block: $5,100
I was simply pointing out that if one is worried about quality, to my knowledge Ashville engines has a perfect track record while Ford has a well known and often lamented track record of building 6.0 engines that fail before 80,000 miles.
Thus, if one is going to worry about quality between Ashville engines and Ford, based on past numbers, Ashville engines is the lower risk.
A Remaned engine is exactly that - a complete engine. Long block essentials include engine block, heads, and internal components (crankshaft, rods, pistons, camshaft, etc.). No external parts are included like manifolds, pumps, turbo, injectors etc.
Looking at the Asheville web site, it seems to indicate that they use your original heads and resurface them. If so, they would charge a lot more if the heads were not re-usable.
As aposed to being scrapped. I am willing to bet that they let a lot more through that would not pass on a Ford
remanufactured engine.
Will the injectors be new,remanufactured,just good enough or not included?
There are very few places that I trust to remanufactured an engine and Lycoming Textron,Continental Motors are the top two
but your not going to find then in a truck. That is unless it's in a shipping crate headed to an airfield.
I would also trust a Ford remanufactured engine. As far as installation that is the easy part. Anthony has proven that time
and time again. He is getting fast at it also.
It's your money and spend it the way you feel safe with. But if you so shortcut to save money
pick carefully on what you do. Pick parts that won't cause a catastrophe failure.
AND NO I AM NOT TRYING TO **** YOU OFF. So please don't take it that way.
Sean
