4x4 issue also
4x4 issue also
My Issue is with the hubs in Auto-Lock I switch to 4 wheel HI, there is a clunking noise while moving and it does not go into 4 wheel drive……When the hubs are locked, there is a clunking noise. I flip to 4 wheel Hi, the clunking is worse but the 4 wheel drive works. When hubs are in auto and is in 2 wheel everything is fine
I would take the hubs off, take them apart and inspect them. If they look ok, no broken parts, grease all the parts up, re-assemble and see how they work. Dont forget to grease the big O-ring on the end of the hub before you reseat the hubs. Check out the link....
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
96powerstroke
02-13-2007 07:56 PM
Chris_94_Ltd
12-07-2004 08:46 AM
