Resistor wire question
Old 01-24-2014, 05:37 AM
yetiman38237's Avatar
yetiman38237
yetiman38237 is offline
So I have been doing some wire rerouting under the dash and I notice this "pink" looking wire from the ignition switch to the firewall. I've got a resistor wire, nothing strange......but, my truck has a stock resistor coil as well. I asked my dad about it and he said he had to special order that from Ford many years ago when the original resistor coil went bad. He had no idea about the resistor wire in the cab so I wonder would this cause any problems with getting a good strong spark at the plugs? I figure it got put on the truck by accident at the factory as I can see no reason to have both....
Old 01-24-2014, 07:03 AM
jim collins's Avatar
jim collins
jim collins is offline
The pink one inside the cab may be burned out inside the covering where you can't see it. Mine was and i had to replace it . I would check it out before removing one of them.__
Old 01-24-2014, 08:50 AM
yetiman38237
I forgot to mention this truck was bought new by my uncle and traded to my grandfather within a year. Nobody has ever worked on it but my father except for alignment until I got it in 99. It appears to have come this was from factory.
Old 01-24-2014, 09:23 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Measure the voltage at the primary on the coil when.running
Old 01-24-2014, 03:47 PM
yetiman38237
I need to do that. It is at least 12 with key on not running.
Old 01-24-2014, 03:59 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Sounds like back in the day someone put Ford's after the factory "transistorized ignition" kit on this truck. Ford had an add-on kit much like the current pertronix. Then someone might have put the points back in it but left the different coil. If you got 12V on RUN then leave the coil there.
Old 01-24-2014, 06:05 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
You will get 12v at the coil with the points open whether it has a resistance wire or not. No load, no resistance.
Old 01-24-2014, 06:29 PM
CougarJohn's Avatar
CougarJohn
CougarJohn is offline
Exactly as above. Pop the distributor cap, manually rotate the crank until the points close. Then, normal would be 7-8 volts if the pink swamping wire is intact.
If you don't get that, report back.
Old 01-27-2014, 02:50 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Hey guys, I thought the load is the resistance built in to the pink resistance wire if it is intact. The 12V running through the resistance wire should be cut down to 7 or 8 whether the points are open or closed I thought. What am I missing?
Old 01-27-2014, 04:33 PM
CougarJohn's Avatar
CougarJohn
The points are a switch. If they are closed, current flows from the ignition switch to ground, through the points.
If the points are open, no current flows, there is no voltage drop across the resistance (pink) wire. You read battery voltage at the top side of the coil.
If the points are closed, current flows. The resistance of the coil primary and "pink" wire are about the same so there is a voltage-divider situation. Ohm's Law splits this drop between the resistance wire and the drop in the primary resistance of the coil. Each gets half. Hence six or seven volts at the top side of the coil with the points closed. 12 volts with the points open.
Semper Fi
Old 01-27-2014, 05:50 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Semper Fi
I figured that if you connect the ohmeter's positive lead to the pink wire and the ground lead to the + coil terminal........but i meant the ohmeter's positive lead to the pink wire and the ohmeter's ground lead grounded to the vehicle. In essence reading the resistance in the pink wire.
Old 01-29-2014, 05:43 AM
yetiman38237
I will have to check that out......as soon as it warms up to 30 or so degrees.......
Old 01-29-2014, 03:23 PM
rustywheel68's Avatar
rustywheel68
rustywheel68 is offline
an electrical engineering degree.
no worries- i don't have one either.
long story short- if the circuit isn't completed (points closed), you can't read the resistance. it'll just show battery voltage.
so- you should always measure the circuit with the truck running- or, you can run a jumper wire to ground the negative side of the coil. anything that will complete the circuit.
my eyes bugged out the first time someone explained it to me- its a hard thing to grasp if you're not an electrician, i guess.
Old 01-30-2014, 03:15 PM
CougarJohn's Avatar
CougarJohn
Jefa, ohmeters don't care about + or - leads. They read resistance. You must disconnect the battery before doing any resistance checks. Or, you will blow the meter movement.
The guy above gave a pretty good explanation, methinks.
Old 01-30-2014, 04:10 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
WOOPS! I did type ohmeter but meant to say Multi-meter. I guess I got to slow down before I hurt myself! LOL! Set to volts, not resistance. Sorry John for the confusion. But I meant positive lead to the pink wire and grounding the negative wire of the Multi-meter.
the Canadian
04-18-2012 11:00 PM
flipklos
05-29-2009 08:32 PM
ramarado
21
03-11-2008 11:12 PM
bivens1172
04-27-2005 12:17 AM
Daddywags
04-19-2004 10:18 PM
Quick Reply: Resistor wire question
