Removing front fenders
#32
#33
I've noticed the same thing. My camera takes "smaller" pictures than the phone. In my case it could be because my camera is old. Only 2.0MP.
I use Paint Shop Pro to reduce the size of everything I post on FTE to 640 wide by whatever it works out to be tall. You should be able do the same thing with most any picture editor.
#34
The clip removal really was not difficult. I wish I would have removed it earlier which would have made the frame component cleaning a lot easier.
If someone is about to remove a clip and needs some specific questions answered let me know before my 67 year old brain forgets what I did.
The picture of the left cowl rust shows the only deep rust Floyd has. I don't know how to fix this sort of thing and since it is nearly unnoticeable when the fender is on I intend to just kill the rust on the cowl and on the cab mount inside and leave it. I will only drive Floyd on non rainy days and he will always be garaged so the rust should not get worse.
I really want to thank all of you who encouraged me and helped me on the clip removal.
This process was something I have never done before and my apprehension exceeded the actual difficulty.
As progress marches on I will post again.
Fred
#36
Just did this yesterday removing fenders on the truck on F800 'plenty of room without taking wheels off. Left fender 4hrs right 5hrs grille 20 minutes. Four bolts I cut with
air cut off whizzer. Left running board AC torch. Fender to running board sawzall right
through the rubbers. I use shock absorber rubbers for that. Two new nos fenders rare as chicken teeth epoxied
primed and finish painted. sam
#37
It was painted and never installed
302ci
13
08-13-2012 03:51 PM
CAPTAIN
02-18-2009 12:38 AM
