Harmonic balancer bolt
Old 01-20-2014, 06:52 PM
chefcharles's Avatar
chefcharles
chefcharles is offline
I am having a heck of a time removing the harmonic balancer bolt on my 360fe. I can't get enough torque without turning the engine over.It's an automatic so I can't put it in gear.Any suggestions.
Thanks
Old 01-20-2014, 07:58 PM
wld427's Avatar
wld427
wld427 is offline
take the starter out and use a pry bar or large screwdriver as a brake.
Old 01-22-2014, 08:27 AM
69cj's Avatar
69cj
69cj is offline
Air impct gun is the way to go.
Old 01-29-2014, 11:19 PM
orich's Avatar
orich
orich is offline
Thanks
I've seen on the forum board where a guy ended up using a pipe wrench behind the damp placed on the spacer holding it.
Also had to use a socket and a long handle breaker bar placed up against the frame while socket on pulley bolt. Remove coil wire and bump the starter. Had to do it this way on my sons Tacoma. It works best with 2 people tho! dangerous yes use a impact socket.
Had to use a cheater handle with my son's truck. His crank bolt torque was like 175-lbs. the only way to remove it with the tools we had. That was common practice with the 4cyl.
Or try duct taping the breaker bar into place & try it..
orich
chefcharles
01-21-2014 09:35 AM
dale88
02-16-2010 12:29 PM
aerocolorado
Aerostar
07-19-2007 04:23 PM
miked79928
General Automotive Discussion
07-26-2004 07:20 PM
bigwhtbco
07-03-2004 08:16 AM
Quick Reply: Harmonic balancer bolt
