Pop-out supercab window retrofit?
Old 01-31-2015, 06:33 PM
SupercabTJ's Avatar
SupercabTJ
SupercabTJ is offline
So I've got a question for anyone who has installed pop-out windows in a supercab with original fixed windows. The latching half is not a problem, but I'm wondering about the hinged side. Where the hinges originally welded in or anything? When I removed the windows from donor truck the hinges were just resting into their slots in the cab, with some old rubber grommet type things with old silicone residue or something. Installing them in mine should just involve cutting small slots in cab to recess hinges, and ( I think two?) holes to mount latch at rear, is that right? I have the different weatherstipping, just wondering about how to attach leading edge hinge into cab. Thanks!
Old 01-31-2015, 07:27 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
The plastic hinges just snap into the slots. Your donor ones must have been broke. New ones snap in tight. I really don't know how to get them back off without breaking them.
Old 01-31-2015, 11:42 PM
buckin69bronco's Avatar
buckin69bronco
buckin69bronco is offline
I don't know about all dents but my 79 had original fixed windows and when I went to pop out ones it had the hinge holes already there. You may have the hinge holes already there too.
djfins
11-07-2018 10:24 AM
supercab79
07-05-2008 06:33 PM
JRCF
05-03-2008 09:47 PM
CO4x4SD
04-29-2004 04:34 AM
HarryL
02-05-2004 07:03 PM
Quick Reply: Pop-out supercab window retrofit?
