Water pump leak.
Check for any play in the fan. If you can move it in and out a little the pump is probably on its way out anyway.
To replace the gasket or the whole pump either way you have to remove it. I would remove it, see if the pump is good and if it is then only replace the gasket. Otherwise the entire thing.
Here's a pretty good write up. I think Billly said in a thread somewhere that he lost his pic account but still has them on the computer. It'd be nice to see them.
http://powerstrokearmy.com/forums/showthread.php?t=3067
IH water pump with filter. - PowerStrokeArmy
And for the cost…
A Diesel Site coolant filter will do the same thing for Less money
HRTKD
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-05-2018 08:52 PM
kbarbee95
11-28-2014 03:38 PM
wesmansr
04-01-2005 08:26 PM
