292 Y-Block Transmission
Old 01-17-2014, 07:26 PM
OKC54f100's Avatar
OKC54f100
OKC54f100 is offline
Does anyone know what Manual transmissions will bolt up to a 292 Y Block?
I understand that it needs the right bell housing but i am in a tough spot and need some of this info.
As far as I know the T-98 works.
Old 01-18-2014, 08:18 AM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
The bell housings fit a Ford "butterfly" pattern. A non-synchronized crash box (T9?) will fit. There are versions of T98, T18 and, likely, T19 that will fit but the input shaft must be Ford-specific. Lengths may vary too. I just rebuilt a T98, it was relatively easy. T98s are not the same internally as a newer T98A but the rebuild parts do match up. Oh, and there are two or more three speeds (T85 and friends) that can fit. Today, John Mummert can help you fit a T5(!). Car and truck applications can vary clutch, input shaft, and mounting of any of these. Sounds rather ambiguous, yes? That's alright - these guys will have many details:
Technical
Last edited by The Horvaths; 01-18-2014 at 08:23 AM. Reason: Forgot all about three-speeds.
Old 01-18-2014, 08:25 AM
The Horvaths
Smile
Oops! WELCOME to the forum!
7.3stroker2
20
10-24-2015 10:39 PM
Chris 56 f6
05-18-2014 11:48 PM
jbarefoot
08-08-2011 11:51 AM
pntrbl
09-23-2005 03:48 PM
ceetwarrior
09-14-2004 12:44 PM
Quick Reply: 292 Y-Block Transmission
