Up pipe interchange?
Hey all, does anyone know of the passenger side up pipe from an 03 6.0 will fit an 05? I have an up pipe leaking I believe as I am getting exhaust smell in the cab when sitting still. I have an extra up pipe from an 03 on hand. I also remember reading a thread where someone upgraded the flex joint on the up pipes but am having trouble locating it. I would like to do the upgrade before installing the up pipe to Save downtime in the future.
I had a leak in the flex joint on my y pipe. I sent mine off to Maryland performance diesel and they put in the heavy duty bellow flex joints. Then i did an egr delete kit with new up pipe while I was in there. If you don't have time for the truck to be down they will send you a set of y pipes you just pay a core charge till you send yours in.
As a side point, I charge $60 to weld in new flex joints.
Josh
Bullitt that's not a bad price at all. But I really can't be down for any length of time. Once I get everything it will be a tear down fri afternoon probably 2-3 hours to build tweak and make sure the jig is satisfactory. Then cut weld and get it back together before Sunday night. I have to get kids to school in the am and work right after. Plus I like to do things on my own. The only thing better would be to have a new turbo back exhaust tonight in at the same time.
If you can do it yourself that would work great. I did t have access to a tig welder or a jig. It was $350 for the new set. MPD 6.0 Heavy Duty Up-Pipes
Just make sure you use the jig like Bullitt has above.
Bullitt I will have to remember you if I ever need any welded in again.
Mark_in_co
11-18-2021 03:18 PM
