I have a 97 f150 v6 and I'm in the middle of replacing the transmission. I tightened the torque converter nuts and was able to turn the crankshaft in the process to get to each one. But after I tightened the bellhouse bolts I couldn't turn it anymore, but I can turn it as long as those bolts are loose. Can someone please tell me where I went wrong? Thanks
I replaced my 99 v6 this summer and had the exact same thing happen. I couldn't figure out why it wouldn't turn. Ended up re-disengaging the tranny and turning the tc by hand. Seemed fine. Re-engaged the trans and engine and everything was good to go.
