1950 frame, long to short
Old 01-05-2014, 03:22 PM
Maxchitley's Avatar
Maxchitley
Maxchitley is offline
forgive me if mess this up, my first post
Is it difficult to shorten a 1950 F3 long bed frame to short?
Not worried about the welding, just if its doable and worth it.
Old 01-05-2014, 03:54 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,469 Likes on 1,408 Posts
Welcome to the forum! If you're a competent and capable welder, or know someone who is, it's certainly doable. Whether or not it's worth it is up to you, and what you want from your truck. The pros that do frame welding will cut and weld at an angle or in a step fashion, rather than a simple vertical butt weld. Gives greater surface area and doesn't crack when the frame flexes, as it's intended to do.
Old 01-05-2014, 04:31 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
From what I remember reading, the frame needs to be shortened in two places. Plus the bed crossmembers need to moved.
Old 01-06-2014, 05:19 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Ilya is correct. Take 8" out of the frame just below the gap between the cab and the box. Then you will need to trim the rear of the frame to match your build plan. If you are putting a trailer hitch on your truck you may want to make it a little longer in the rear. I'll post some pictures that are on my other computer. As Ilya says you will need to fabricate some cross members and shims to match the box that you are using.
I think that you will need to get some F1 emergency brake cables too.
Hopefully you will be changing the suspension too as the ride was pretty severe on my F2 . . . Can't imagine what an F3 would be like.
Old 01-20-2014, 12:38 PM
Maxchitley's Avatar
Maxchitley
thanks for the info
Thanks for all the reply's.
I found a short bed frame, but concerned it might be a 1947.
Is there a quick way to tell the difference between a 47 and 50 frame?
Thanks
jimc2004
11-16-2008 10:55 AM
BACAGrizz
07-21-2008 12:39 AM
wildstang
Paint & Bodywork
06-29-2008 07:20 AM
ksmith203
11-16-2006 08:48 PM
roan65
Paint & Bodywork
08-08-2006 07:18 AM
Quick Reply: 1950 frame, long to short
