What do i need to do to make my truck 4 wheel drive
Old 12-28-2013, 11:55 PM
Muddog99's Avatar
Muddog99
Muddog99 is offline
I dont think the title to my other thread caught your eyes i have a 65 f250 with a straight axle front its 2 wheel drive but how would i go with a divorce transfer case and drive shafts how would i go about the lever for the transfer case and what about different 3/4 ton axles under it or could i use those ones
Old 12-29-2013, 12:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Muddog99
I dont think the title to my other thread caught your eyes. I have a 65 F250 with a straight axle front its 2 wheel drive.
1965 F250 2WD came with Twin-I-Beam front suspension with coil springs.
If you have a straight axle and 2WD, it's a 1961/64 F250 with leaf spring front suspension.
Old 12-29-2013, 12:53 PM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
It would take a lot of custom fabrication and welding you need to make a transfer case mount and figure on making all new driveshafts front rear and center or get a married t case but then you'll need to get a trans to mate up to a t case. Front axle new headers to clear the front axle pumpkin probably a front axle make leaf spring mounts and shackles depending what's goin on with your truck id figure the vin number matching the rest of the truck first.
Old 12-29-2013, 12:54 PM
dsrtjeeper's Avatar
dsrtjeeper
dsrtjeeper is offline
Slide an F150 4x4 chassis under your body and get to work.
Old 12-29-2013, 01:30 PM
iggybob44's Avatar
iggybob44
iggybob44 is offline
First off, the T-case lever is the least of your concerns.........Im not sure what your getting at regarding your axles, clearly you cant use your existing axles, since you have 2wd axles currently. Easiest solution is to buy an existing 4wd truck, or at least a 4wd chassis from that era.......
Old 12-29-2013, 05:10 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
If you do have a stiff axle front end, you just need a donor truck for the axles, u-bolts, t-case, etc. It shouldn't be to hard.
Also, periods and capital letters make things easier for slow people like myself to understand.
ilovemy60ford
02-04-2011 09:31 AM
YamakidCR500
03-02-2010 02:50 PM
ford4x4s
03-15-2009 03:35 PM
pointman
09-17-2005 10:03 AM
Quick Reply: What do i need to do to make my truck 4 wheel drive
