Weathertech Techliner
Anyone have one of these?
I am thinking of taking out my ford drop in Bedliner and getting a bed mat that I can cut a hole in for the B&W turnover ball, and be able to sit the companion hitch on the bed mat.
I'm not sure if this would work on the techliner or if another rubber mat would be better.
Cutting a hold for the goose ball is not big deal, but I would be concerned about sitting a Companion hitch on top of a soft rubber mat like that. With pin weights well over 3,000 lbs with today's big fifth wheels, you are going to have stability issues with the hitch sitting on that rubber.
How would you address the depressions in the bed? I have the B&W provided spacers installed on my Companion to make up for the depressions, but how would you handle that with the mat? I currently have an old rubber bed mat in my truck and have cut a square out of it for the Companion. When I'm not using the hitch, I lay the square back in the mat. I wouldn't want to do that with a new mat, but I don't want the hitch sitting on top of a rubber mat either.
Yeah, back in 2005 they said it was alright to use it on a drop-in liner. I used it on top of a Duraliner, which was certainly more robust than some of the other drop-ins I've seen. I did not have any problems running it with the Duraliner. I ran a Dual-Liner in my 2008 which only had a heavy duty bed mat on the floor. I used a hole saw to cut access the B&W and then torqued the Companion down to the mat.
dt444e
Fifth Wheel & Gooseneck RV Towing
09-23-2007 01:31 PM
Catfish_Man
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-12-2004 04:35 AM
