WD-40 defect?
WD-40 defect?
One of my few uses for this stuff is as a lube for working with aluminum, it's some of the best stuff I've ever found for keeping the material from sticking to the tools.
I was happily working along tonight, when my WD-40 went dead. There's still a lot of fluid in the can, maybe around half full, and there's enough pressure that I can't dent the can with my thumb, but nothing comes out. This is the fourth can in a row that has done this to me, and they all plug inside the can so it's not just a matter of clearing the nozzle.
Has anyone else noticed this or am I just getting odd failures?
Ditto. If memory serves me it was not too long ago same/similar thread where member's complained about half full WD containers losing pressure, and seem to be more with the 'flip straw' type applicator??
Don't know anything about it, but I have an aluminum question. (Just a small hijack)
Quite a few years ago, The product I worked on used large 3/8" aluminum baseplates --something like 4 x 6(feet). Originally, they were all custom.
A machinist who used to do them used water when he was tapping the holes -- said it worked great. Has anybody ever tried that?
Might have been 6061, but it's been 30 years or so.
hj
hj
hj
hj
I have avoided punching a hole in the can since it still has pressure. The last thing I need is an uncontrolled release of WD40 plus whatever flammable propellent they use.
I do plan on getting a gallon and a spray bottle, or set up a drip on the cutter to save some time.
I saved money by getting a pneumatic sprayer I can refill. WD is great for milling and drilling aluminum, but not much else. I'll pass on using water since even water-based coolant isn't as effective as WD-40 for machining, and using pure water on machine tools is begging for rust.
I have no problem walking outdoors with any spray can (wearing eye protection) and putting a very small hole near the top of the sidewall with my multitool to depressurize it. If you have one of the old-style refrigerant can piercing tools that's even better for dumping the propellant.
Received 3,992 Likes
on
Funny reading that here. This morning I was reading a blog on another site that mentioned that the primary ingredient in WD40 is fish oil. After reading what you wrote I'm thinking that maybe that is true.
on
A true story. When I was still heavy in national level competition shooting, we had to have a minimum of 3 pounds of trigger pull on the one class of rifle. We would strip the trigger mechanism and spray it down with WD 40. At the weigh in the trigger pulls would check in at or just above 4 pounds. As soon as we were weighed, we would clean the WD 40 off with degreaser and recoat the sear and the rest of the trigger mechanism with Never Seize compound. It dropped the trigger pull down to between 2 and 2 1/4 pounds.
With the above exception, WD40 is never allowed in the same room with my guns.
