1500 watt block heater for 6.0?
Old 12-06-2013, 04:28 AM
Number21's Avatar
Number21
Number21 is offline
Had my block heater plugged in today for 3+ hours and still only hit about 75 degrees on my scangauge. That's plenty warm to get it started but still nowhere near operating temp and not much heat. Most of the time I only have time to leave the block heater plugged in for an hour or so.
Is there a 1500w heating element I can install in my 6.0? The factory heater is supposed to be 1000w but I measure only 900. I have seen them for the 7.3 but not the 6.0. Does anybody know what size the threads are?
Old 12-06-2013, 03:00 PM
IHbase's Avatar
IHbase
IHbase is offline
More heat seems like a bad idea- it does not get serious cold in Oregon and then stay that way for weeks like Montana, the Dakotas and Minnesota. Block heaters are not intended to keep a motor at operating temp and you probably would not want to pay the electric bill if they did. Seems like fixing something that is not broken. In extreme cold the next steps are battery blankets and transmission heaters- but you would never need them in Oregon. -Mike
Old 12-06-2013, 03:56 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
If you need more heat and I don't think you do. Get a
stick on heat pad and stick it on the oil pan.
Have a look at this link.
E-Z HEAT A/C ENGINE PREHEATER from Aircraft Spruce
Sean
Old 12-06-2013, 04:05 PM
Number21's Avatar
Number21
Number21 is offline
Like I already said, I know I don't NEED more heat, but there is certainly nothing that makes it a "bad idea". The closer it is to operating temperature the better it is for the engine, and the better it is for me. That's why mission critical diesel generators in places like hospitals, have circulating block heaters that keep the engines at around 180 degrees full time. (So they can just start up and go) Electricity is far, far, far cheaper than diesel and my engine gets twice or better MPG when it is warm. 5-10 miles at operating temp vs 5-10 miles warming up is a BIG difference in fuel.
I am already going to install an oil pan heater since there is nothing the block heater could ever do for all that cold oil in the pan. But the 900w block heater is still extremely weak. Your average water heater holds 40 gallons of water and has a 5500 watt element. My engine has 15 gallons of fluids and 1,000lbs of steel to heat up with just 900 watts. 1500 watts cost about 15 cents per hour, if I can afford the diesel I can afford that.
Old 12-06-2013, 04:28 PM
gunnarGSD's Avatar
gunnarGSD
gunnarGSD is offline
Your 900w block heater is not warming up all 15 gallons of your coolant. It is warming the coolant in the block. When I start mine the coolant temperature actually drops a bit as it starts to circulate then recovers fairly quickly. -15f were I am at right now and by the time I leave my neighborhood I have decent heat coming from the vents and defroster after being plugged in. Hate to say it but this time of year with the winter fuel in cold climates we all get crappy mileage, it is what it is. But like other have said I don't think you need it either.
Old 12-06-2013, 04:50 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Do to convection you do get some heating of the
radiator. The warm fluid moves up and the cold
fluid moves in to take it's place and as it cools
it drops and the cycle goes on.
It's just not driven by a pump. Speaking of you could
make some system for quick disconnect and pump
heated coolant into the engine. The hard part would
be a valve that does not loose fluid in the connect
disconnect process.
Sean
Old 12-06-2013, 05:05 PM
gunnarGSD's Avatar
gunnarGSD
Theoretically I guess that's true but there is no direct link between the coolant in the block and the radiator once the thermostat closes. The radiator is blocked off by the thermostat and the water pump. But if it's cold enough for you to use a block heater I don't see any benefit from convection heat.
Old 12-06-2013, 05:16 PM
Number21's Avatar
Number21
Number21 is offline
Yes...right now I'm not heating the coolant in the radiator (or the oil in the pan) and that's part of the problem. Big drop in temp as soon as the engine starts. I've considered installing an auxiliary electric water pump to circulate water when the block heater is on. This way I could pre warm the cab without the engine running. (Pumps are cheap) If I can't find a stronger block heater I'll probably install a tank type heater.
And again I usually don't have 3+ hours to leave it plugged in. I want it warm in an hour, hot in two. I don't work on a normal schedule, I don't know when I'm going to leave. I can't use a timer.
Yes, I know I don't NEED it. Nobody in Oregon needs a block heater. I don't need leather seats either. But I have them.
Old 12-06-2013, 05:49 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Heat transfers through the metal and will in fact heat the upper hose it just slower.
Sean
Old 12-06-2013, 05:58 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I've always been the naysayer when it comes to plugging in, but I have plugged in 3 days this week and with temps at -9 and colder each overnight and morning
I did the timer at 3 hours and it was at 54 ECT
5 hours was in the 60s
7 hours at -9 temps was at 75 ECT this morning.
Josh
droldsmorland
1999 to 2016 Super Duty
17
01-03-2017 02:54 PM
73f100shorty
06-27-2007 04:51 PM
boomer 453
General Diesel Discussion
12-27-2006 04:27 PM
Truckasaurus
2004 - 2008 F150
15
12-08-2004 10:11 AM
iceman5
10-20-2004 06:38 AM
Quick Reply: 1500 watt block heater for 6.0?
