I bought a new 08 f250 diesel in 09. At the time I bought the extended warranty. I have less than 50,000 miles on it, yes I need to drive more. My time will end this next March. I can purchase another extended warranty, VSP, for about $2000 for another 60,000 miles. Would this be a good purchase or would it be better to pass. Your opinions appreciated.
My 09 has about 75000 miles and I decided to get one-similar to you. Search the forum and you'll find the best way to go. I bought mine from lombardfordwarrantys.com as they had the best price.
Only thing paid for was batteries. Everthing else has been covered by warranty. Hpf pump wiring harness. A SENSOR power sterring and bad tires. That's all so far.
Mine warranty has paid for itself a already
Had following repaired under warranty
Blower motor
6 disc changer
Hydro boost, drag link, gear box tightened up
Oil cooler, t-stat (cab off repair)
EGR sensor
