Ford 1971 F600 Motor Size?
Looking to buy a 1971 Ford F600 2 ton dump truck. But the guy doesn't know what size motor is in it. Can Someone help me out. Here is the info I gotten off the truck. Thanks
VIN: F61DVK80401
This is stamped on the intake C7TE 9426-K
Has 2 barrel Holley Carburetor
Firing order that is stamped on the intake 15426378
This is the stamped on the rearend housing 115456
VIN: F61DVK80401
This is the VIN decode
<table border="" cellpadding="1" cellspacing="0"><tbody><tr><th>Digit</th><th>Usage</th><th>VIN</th><th>Decoded</th></tr><tr><td>1-3</td><td>Series</td><td>F61</td><td>F600</td></tr><tr><td>4</td><td>Engine</td><td>D</td><td>V8 330</td></tr><tr><td>5</td><td>Plant</td><td>V</td><td>Kentucky Truck</td></tr><tr><td>6-8</td><td>Mod Yr/Mfg Date</td><td>K80</td><td>1971 (Mfg Jan 1971)</td></tr><tr><td>6-11</td><td>Sequential Serial #</td><td>K80401</td><td>K80401</td></tr></tbody></table>
Ok thanks, but is that the firing order from the intake on the F330. I don't know.
Firing Orders for Ford Engines
Greg is correct but just to expand on it the letter "D" equates to 330 "H.D." So it will be a big snout crank etc. closer related to the 361 and 391 IF IT'S STILL THE ORIGINAL ENGINE. The 330 M.D. were closer to a 360/390. The 330 H.D.'s were interchangable with the 361 and 391's. I've only ran across 330 H.D. and 361's being Holley 2v. Usually with a governor. All 391's with a 4v governed. Original equipment,that is.
Not necessarily. It could also mean it was originally designed for that year (but also used after that year).
VIN: F61DVK80401
VIN: F61DVK80401
VIN: F61DVK80401
VIN: F61DVK80401
Laura An Michael
02-02-2019 11:30 AM
Mike5737
2017+ Super Duty
108
02-23-2018 03:55 PM
