Recommendations - W or W/O Sub-Woofer
Hey Guys,
I'm trying to configure a system for my 2005 F350, which is a regular cab. My primary concern is whether I need a sub-woofer or will the bass be sufficient with only component speakers. What do you recommend? It it worth the additional $344.98 for the 5-channel amp, 12" sub-woofer, and box enclosure?
Head Unit - Pioneer AVIC-X910BT - $618.00
Pioneer AVIC-X910BT (avicx910bt) - Car Stereo Head Unit In-Dash Receiver - Sonic Electronix
Component Speakers (F&R) - Polk Audio MM6501 - $199.99 Each
Polk Audio MM6501 - 6-1/2" Component Systems - Sonic Electronix
4-Channel Amp - Polk Audio PA500.4 - $209.99
Polk Audio PA500.4 (pa5004) - Multi-channel Amps - Sonic Electronix
Total: $1,227.97 w/o Sub-Woofer
5-Channel Amp - Polk Audio PA1100.5 - $399.99
Polk Audio PA1100.5 (pa11005) - 5-Channel Car Amplifier/Amp - Sonic Electronix
12" Sub-Woofer - Polk Audio MM1240 - $129.99
Polk Audio MM1240 - 12" Subwoofers - Sonic Electronix
Single 12" Angled Truck or Hatchback Box (12ANTCM) - $24.99
Custom Enclosures 1TRUCK12 - 12" Angled Subwoofer Enclosures - Sonic Electronix
Total: $1,572.95 w/ Sub-Woofer
Those component speakers have a frequency response of 40-25,000 Hz. I know that I will get a lot more "thump" with the sub-woofer but is it worth the extra money?
You will regret not putting in a subwoofer regardless of what kind of music you listen to. Unless it is strictly talk radio. Component speakers do a great job of sound reproduction - but they have limits. Depending on your type of music, I don't know that I would get a 12" subwoofer. I would probably use a 10" if available (personal preference). I have run 15"s, 12"s,10"s and 8"s - both individually and up to four together in trucks and sport utilities - I have found the 10"s or single 10" to be the most versatile subwoofer. I am going to tell you in advance that a regular cab pickup is difficult to get good sound from a subwoofer though. Just my 2 cents. Thanks, Mike
Even though the components are rated down to 40hz, it takes substantially more power to produce 40hz from a 6" woofer than it takes to produce it from a 10" sub woofer. The power difference makes the lower freqs levels drop sharply, but a sub would overlap a little and even out the levels of the range.
- Human hearing only extends down to about 96Hz on most humans with zero hearing loss, and then the sense of feel takes over down to about 20Hz.
- An octave below 100Hz is 50Hz. Another octave below that is 25Hz.
MN_Viking
10-07-2011 08:51 PM
rtazz17
01-01-2010 10:11 AM
rtazz17
12-13-2009 09:23 PM
jjg052590
01-05-2009 09:28 PM
98greensi
10-03-2008 12:28 PM
