No Crank/Start in Park
Forgot about this common issue with the Superduty and Excursion vehicle that while it won't leave you stranded, it is a pain to live with. It has to do with the shift linkage bracket bolts coming loose and losing the shift cable adjustment as a result. Check out the video, as you will likely run across this at some point in your ownership of the Superduty. I hope my video helps!
dtmfman
1997-2006 Expedition & Navigator
06-11-2013 08:30 PM
LUMBERMAN
02-22-2010 11:31 PM
