Turbo Trouble after EGR Delete
I need some advice. I have a 2006 F250, and i have had an EGR delete kit placed on it. The kit seemed to fix my turbo woes until recently when i heard a high pitched whistle followed by a big boom and a puff of black smoke in the rear view. The turbo gauge went to 0 and my truck had a significant loss of power. Some have recommended a turbo rebuild while others think the waste gate may be stuck open. Any suggestions?
YOU Blew a CAC BOOT most likely Turbo is FINE
EASY Fix
Check the 4 Rubber boots coming off turbo follow Plumbing around
Most Common one with issue is Rubber Boot at Turbo
It might of just Slipped Off
or Split a Hole
Let us Know what you find
This truck has No Waiste Gate Unless you count EGR Valve But that's Not your Deal anyway and a Different storey
Welcome to FTE
EASY Fix
or Split a Hole
Welcome to FTE
Dcr31686
11-09-2015 10:03 AM
