400M Pulleys
400M Pulleys
Hi, Anyone know where I can get NEW pulleys for the 400m. After 35 years of use mine need to be replaced. I am having a hard time finding stock pulleys since support for these engines are limited. I know there are aluminum pulley kits for this engine but I want to stay away from them since they are over price and will wear out faster. Do any other ford engines share the same pulleys as the 351/400. I know that the 302/289 has good parts support so would I be able to piece together different pulleys from other engines. I am in need of a Crank pulley, P/S pulley, W/P pulley, and Alternator pulley.
Thanks
Thanks
Do you have factory A/C. Is the alternator single or double belts, does your truck have (or had) an air injection pump?
And last but not least, what truck do you have, year, model, 2/4 WD? Truck serial number (last 6 digits of the VIN)
The reason I need to know all this stuff is:
There are 5 different crank pulleys, 3 water pump pulleys, 2 alternator pulleys, and 5 power steering pulleys. If your truck is 4WD I need the s/n to look up the right power steering pulley.
No factory A/C, just the under dash heater, alternator has single belt. Not sure if it ever had an air injection pump. The truck is a 78 F250 4WD.
Okay, here we go .
Crankshaft Pulley
Fits 77-up F100-350 w P/S w/o Thermactor emissions
4 shieve marked D3DE 6312-AA
D5DZ-6A312-A
B&B Auto Parts, Bronx, NY has 1 (718) 892-1186
Water pump
Fits 77-up F100-350 w P/S w/o AC
Single shieve 6-61/64" diameter Marked C9OE-G or D1AE-BA
C9OZ-8509-D
Inventoried as C9 "letter O" Z
Tison Motor Co., Estill, SC has 1 (803) 625-2551
Inventoried as C9 "zero" Z
Green Sales, Cincinnati, OH has 10 (800) 543-4959
Dennis Carpenter Obsolete, Concord, NC has 1 (704) 786-8139
Power steering
Fits 78-79 F100-350 w/ 4WD before s/n EA0,001
D0AZ-3A733-A
Wesley Obsolete Parts, Liberty, KY has 1 listed as D0AZ and 1 listed as DOAZ, probably the same part listed both ways (606) 787-5293
Alternator pulley w/ 40,60,65 amp alternator
78 w/ 400, single groove, type 3
C5AZ-10344-K
Dennis Carpenter has 14
Wesley Obsolete Parts has 2
NOS Parts Source, Olathe, KS has 1 (913) 220-5746
Freese Motors Inc., Monticello, IA has 2 (319) 465-3541
Whenever there is a numeric 0 or an alpha O in the part number prefix, its often entered into inventory incorrectly so I search both ways. Thats why there are a couple of pulleys that I list with the two different, but same, numbers.
Also, on the pulleys that I listed with an engineering number, that number should be stamped on the pulley. If you see a different number let me know what it is and I can cross it to the correct p/n.
Crankshaft Pulley
D5DZ-6A312-A
Water pump
C9OZ-8509-D
Power steering
D0AZ-3A733-A
C5AZ-10344-K
Ricardo Chambers
17
07-31-2017 05:14 PM
V8orBUST
05-26-2014 02:43 PM
tractormanbill
01-10-2014 01:15 PM
79FordBlake
04-19-2011 08:52 AM
