Dual V-belt alternator pulleys
I want to do a 3g alternator upgrade and want to run dual vbelts off of it.
I have the 1st crank groove going to water pump and power steering and the second currently going to my alternator. 3rd groove is empty but slightly different in deepness of the groove.
Is there a factory crank pulley that has the last 2 grooves the same as well as an alternator pulley with 2 grooves i can pull out of a Junk yard?
Perhaps NumberDummy can help me understand what I discussed in that thread?
By the way, here's how I'm going to do it. The idler pulley is a combination of the pulley from a 460 with a serpentine system, and it is mounted on the standard idler bracket for an M or W.
Yes, it is the crank pulley I was talking about. I need one as well. But the parts catalog is quite confusing so I haven't figured out exactly what vehicles it comes on besides the 86 EFI'd 302 I found it on. I will try to get clarification.
As for the alternator pulley, these people have everything needed to repair or upgrade alternators, inc pulleys. The 3G I got from the salvage has at least one bad diode so I'm going to use their 160 amp diode bridge. Plus a new LRC regulator so it won't squeal the belts on startup.
Also, some have said that most v-belts aren't made for wrapping backward. Did you use a standard belt? Have any problems?
dual V belts
Gary,
I used a NAPA stock replacement belt, the flat pulley on top of the belt had the belt going on to the AC pulley below the centerline of the AC pulley. I used the same idler type system you have with a V belt pulley. Have not had any problems. You just have to make spacers to align the V belt idler with the other pulleys. I started with 1/2" thick spacers and adjusted from there.
Rodger
Rodger
Montync
04-20-2016 07:14 PM
DPDISXR4Ti
05-02-2013 03:38 PM
tombogue09
06-11-2012 03:24 AM
Cyberbug
12-19-2005 12:44 PM
