6.2L V8 Discuss the 6.2L V8
F250 Bags or Blocks
Old 11-09-2013, 03:03 PM
Framy's Avatar
Framy
Framy is offline
bags or blocks
I have a 2012 F250 without camper special equip. I pull a 14,000lb 5th wheel toy hauler. I put the Firestone bags on with a air compressor mounted under the washer fluid tank and the switch and gauge under steering wheel. I love this combination, when pulling the 5th wheel I pump the air up to 35-40 lbs without any weight on the box. With the 5th wheel weight (2200lbs hitch weight) the air pressure on the gauge goes up to 55-60lbs. This improved the ride a lot and when running empty I lower it down to 10lbs.(firestone recommends it be no lower than 5lbs). I don't really notice any difference in ride if I leave the bags pumped up or at 10lbs The reason I lower it is to lower the box when running empty.
Old 11-09-2013, 06:16 PM
dirtymutt's Avatar
dirtymutt
dirtymutt is offline
This has been great feedback. I was leaning to blocks originally but now i think I'm going to go the airbag route. I like that the truck stays the same for warranty reasons and I bet the 5lb min pressure in the bags will be just enough to alleviate the front high when empty. Thanks for the help.
Old 11-11-2013, 02:37 PM
AirLiftCompany's Avatar
AirLiftCompany
AirLiftCompany is offline
SPONSOR
We have a rebate offer going on right now, up to $100 in savings. You can learn more about it here: Air Lift Mail In Rebates | Air Lift Company
Hesson81
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-15-2019 10:17 AM
BrianF-250
Fifth Wheel & Gooseneck RV Towing
12-02-2017 10:56 AM
RickBetterley
1999 to 2016 Super Duty
29
04-20-2012 12:54 PM
Newfordguy33
2009 - 2014 F150
23
03-20-2012 09:01 PM
dennylm
12-26-2006 08:40 AM
Quick Reply: F250 Bags or Blocks
