2017 150 and gooseneck
I currently have a 2011 250 CC/SB 4wd with 6.2. I got it new and it has been fine but after having diesel SD's for so long it has been tough not having that turbo to kick in especially when towing. A friend bought a 3.5L with the max tow and has hauled a large camper all over the country for the last year and loves it. I just purchased a '17 3.5L with 10 spd tranny and max tow package. It will be great for my camper and am planning on a WD hitch to keep it level. I have air bags on the 250. I also have a Sundowner 4 horse gooseneck so plan on putting the B&W in next week. My question is will I need air bags with the gooseneck. I will be traveling short distances with the horse trailer but don't want to totally squat the truck. How much weight over the axle will the truck handle? The trailer is all aluminum and not that heavy. Probably less than 8k with horses. I found out with the 250 that the airbags are a lot easier to install before the hitch but don't like the ride they create.
Thanks.
Brian
Thanks.
Brian
Keep in mind that this will not be 100% accurate for each and every truck. Number of passengers, gear, whatever else you have in the truck, plus the tires they put on it may effect it too.
You will want to check those tires and make sure they are LT e rated, not P tires.
I would also get it on the scales and see what the actuals are per axle and compare that with the door sticker and sidewall of the tires.
I’m not sure I will either, but it’s what I have now so I will see how it goes and make adjustments as needed. I pull that trailer so little these days and mostly just within a 10 mile radius that hopefully I will get by. If the kids decide to rodeo, then I guess it will be back to a bigger truck.
F-150 Towing
I've towed 11,000 with my 2015 F-150 KR Screw FX4 ecoboost. No issues with power, it pulls very diesel like. But stopping...thats a whole issue on it own. I had a trailer brake failure while towing, I slid halfway through an intersection because the front brakes kept trying to to lock-up even at very low speed on flat terrain. The anti-lock kicks in, but the fronts still skidded badly. It was a wake up call for sure. Not saying its not doable, but its going to have some serious limits that a super-duty DRW would laugh off. I returned from the same trip, same route but down to 9,000 lbs total and that felt very secure.
Hesson81
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-15-2019 10:17 AM
Rusty_S
05-18-2014 06:41 AM
dana_wildcat
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
07-29-2005 09:19 PM
