The bracket is attached to a rod and a beating and then a bearing and another rod attached to something that's braced and the lines, possibly fuel, go up ontop of my rear tank.
Looks like its linked off the diff housing, if so it should be the rear brake proportioning valve, it increases rear brake as you increase the load at the rear. Always remember to modify the linkage length in proportion to any rear spring lift or lowering you do.
My parking brake doesn't engage, like when you push on it it kind of twists to the side, I haven't looked at it much but I think maybe it's rusted and something broke holding it. Or maybe something is just really right on it?
