Hey Guys really need your help .Starting problem
Hey Guys its been a while since i've posted on these boards . For the last few months my truck hasnt started . it got put on the back burner between working and after work going out into the fields to harvest, and now the truck has been demoted as a dd to a truck i want to start fixing up.
96 5.0L
So anyways the problem i am having is the truck just makes one click at the starter and wont even try to turn over . Ive put on two starters . and along with the other starter they all do the click .this last starter has given me the strongest click of any. Know correct me if im wrong but by jumping the solenoid on the fender wall it should theoretically try and turn the truck over , but its not it just doesnt the one click and wont do anything else.
Any ideas?
also i put a socket and strong arm on and am able to turn the engine over so i know its not seized.
and of course heres a few pictures so that you guys know why i want the truck up and running.
96 5.0L
Any ideas?
Did the starters you installed have the 1/4" quick disconnect on the solenoid, or did they have the post?
Seems Ford had Some Problems with that Q-D and reverted to a post on the starter solenoid and a ring terminal on the wire. For easily seven years I repeatedly had to dive under the right side of my '94 and move that Q-D around to scrape the crud off it so I could start the truck -- either that or park it on a grade so I could get it rolling fast enough to pop the clutch in 2nd and start it. I finally had to replace the starter when the 1/4" terminal on the starter solenoid built up enough crud that I couldn't scrape it off with my pocketknife and restore contact. That's exactly what it sounded like -- an emphatic "KLIK!" instead of the sounds of a V8 turning fast enough to start.
Sounds dumb, but I installed a starter once that would only click. There were two small terminals on the solenoid, and I hooked to the wrong terminal. Not sure what the other one is supposed to do, but I switched and it was good to go. Do you have two terminals? Really I have no idea but it might be worth a check. My problem was on an F-700 with a Cummins.
Did you have the battery load tested??? No just metered to say you have 13 - 14 volts. If you have a 300cca battery and it's only pushing 200cca it's not going to turn the engine over. Take a known good battery and install it in the truck. it should spin it. Or if you're insistent on using the old one then when someone turns the key over, with your fluke on the battery, see what the voltage drops to. If it's dropping to 6 - 9 volt I'd bet the battery is the culprit, just because you said you already put a new starter on.
Received 3,108 Likes
on
Ok quick update went and metered the solenoid on the fender and the starter they both or reading the same as the battery wich guaranteed needs to be charged will throw it on a charger tonight , battery was reading 12 v and would drop down to 6-7 v when I tried to start it . What's this small trigger wire ?
My starter has 3 post but only two wires .the one post is grounded to the solenoid on the starter and wired up like the old starter was . ,y starter does have a quick disconnect but the wire goes to the post that connect is attached too.
on
on
jrv7874
10-25-2007 09:52 PM
kyleacclaim
4 Cylinder Engines
12-26-2004 11:42 AM
