Sponsored by: Real Truck
starter problem
Old Nov 12, 2006 | 08:19 PM
jbs03ranger's Avatar
jbs03ranger
starter problem
my 1997 f250 351 4x4 is giving me problems. the starter is just clicking. it wont turn the engine over. had the starter checked and it is still good. also the battery is fully charged. i cleaned all the contacts and all were good.... so i am out of ideas... can any one help?
Old Nov 12, 2006 | 08:35 PM
ohboy44's Avatar
ohboy44
Are you sure the starter is making the clicking sound? Check the starter solenoid.
Old Nov 12, 2006 | 09:42 PM
ReAX's Avatar
ReAX
Usually a solenoid, but i have seen a bad battery connection cause that kind of problem two.
Old Nov 13, 2006 | 04:50 AM
DetailerDave's Avatar
DetailerDave
I had a similar problem. Turned out to be the battery cable. Check the voltage at the starter (bat) terminal. Then try to start it with the VOM still hooked up and read the voltage. Mine would drop down to 1 volt.
Old Nov 13, 2006 | 08:34 PM
jbs03ranger
the starter solenoid checks out good.
Old Nov 13, 2006 | 08:58 PM
ReAX's Avatar
ReAX
Can you turn the engine by hand?
Old Nov 13, 2006 | 09:09 PM
jbs03ranger
i will try that tomorrow
