Well the nut came right off with the impact wrench. Now on to the pitman arm puller. I have it on and tightened down as far as I can take it. Nothings budged. I wonder if I can use the impact wrench here too? I'm guessing I will break the puller but I've already tried pb-blaster and a hammer. If it has not popped by tomorrow I will have to try the impact wrench.
An impact on the pitman arm puller bolt won't do much besides break the puller. Pitman arms typically pop off pretty easy. What you can do is to smack the bolt head with a heavy hammer to shock the arm loose while it's under pressure. It's designed to take that kind of punishment.
Well I beat on it for several minutes to no obvious effect. Put a little heat on it. Just a couple of minutes with a blow torch and it came right off. Now I just have to get the box past the exhaust. ..
Reason: spelling
