struck steering wheel
Old Nov 3, 2013 | 02:05 PM
obscurity's Avatar
obscurity
I have been reading a bunch of posts on pulling a steering wheel. Several suggest that you will need to Drill and tap two 1/4" holes. There does not seem to be much meat for those holes. Is that the only way? I have tried pb blast and beating on it. I have wiggled it back and forth. It does not budge. I could use some suggestions.
Thanks for any help ,
John
Old Nov 3, 2013 | 02:39 PM
jimcar-9's Avatar
jimcar-9
In my steering wheel there was 4 "stock" holes 2 where already threaded, maybe by some previous owner.
Old Nov 3, 2013 | 02:47 PM
obscurity's Avatar
obscurity
Sadly mine is completely devoid of extra holes.
Old Nov 3, 2013 | 02:55 PM
Gicknordon's Avatar
Gicknordon
Mine also didnt have any holes. I pretty much ended up destroying the wheel trying to get it off, but i was planning on getting a new one anyway. I think drilling will be your best bet.
Old Nov 3, 2013 | 03:39 PM
helicopterman's Avatar
helicopterman
I just took my steering wheel off to centralise it. Wiggling did not work. I drilled and tapped two opposite 5/16" holes (about 1/2" deep) and screwed in two threaded bars, then drilled a piece of angle iron for the bars to go through with a washer and nut on the end of the bars. I put a bolt in the steering shaft hole to protect the thread and put a socket between the angle iron and shaft and tightened the nuts evenly. It released with a satisfying 'pop'.
Good luck.
Old Nov 3, 2013 | 04:26 PM
obscurity's Avatar
obscurity
Good luck.
I have tried something similar without the drilling. I set up a couple of wood blocks below the wheel with 3/8"threaded rod running from there to an angle across the top. I ran a 3/8 threaded rod into the shaft worth a but and washer to sit on the top of the shaft threads and another nut to hold the angle off of the wheel then I tightened the side nuts evenly. After applying a fair amount of force I beat on the end of the center rod to encourage it to release. Also used pb blaster. Nothing gave. I guess tomorrow I will try to tap some new holes but after today I may just have to cut the wheel off.
John
Old Nov 3, 2013 | 04:41 PM
helicopterman
My first attempt was with 6mm (1/4"). Kept breaking so redrilled to 8mm (5/16")
Old Nov 3, 2013 | 04:45 PM
helicopterman
Old Nov 3, 2013 | 05:14 PM
4tl8ford's Avatar
4tl8ford
Go buy a cheap Harbor Freight steering wheel puller
Take the silver 4 prong hub and use it to mark 2 holes across from each other as close as you can to the column shaft - Drill and Tap for a 5/16 bolt, which comes with the set
Old Nov 3, 2013 | 07:16 PM
abe's Avatar
abe
The Advanced Auto store in my town let's you borrow a puller for a $20 deposit returned to you upon return of the puller.
Old Nov 3, 2013 | 08:27 PM
4tl8ford's Avatar
4tl8ford
Should of thought about them - I just borrowed a Pitman Arm puller last week - Had it about 3 hrs - It was $16.90 rent/refund - I even gave them their dime back so I could get even money
Old Nov 6, 2013 | 08:26 PM
obscurity's Avatar
obscurity
Don't know if it was the pb-blaster or using the right tool (bought a $10 puller from Napa) but it came right out. For the next piece, Can I take the pitman a nut off with an impact wrench of will I damage something?
Old Nov 6, 2013 | 08:44 PM
4tl8ford's Avatar
4tl8ford
You should be OK using a impact wrench, However after you get the nut off you are going to need a Pitman Arm puller - They can be rented free form most of the AP stores
Old Nov 7, 2013 | 06:59 AM
cruisetopdown's Avatar
cruisetopdown
I used a puller from the local auto parts rental fleet....the wheel didn't budge after I applied a lot of pressure, so I just let it sit with that pressure on it and it popped 10 minutes later.
w
Old Nov 7, 2013 | 09:12 PM
obscurity's Avatar
obscurity
Well the nut came right off with the impact wrench. Now on to the pitman arm puller. I have it on and tightened down as far as I can take it. Nothings budged. I wonder if I can use the impact wrench here too? I'm guessing I will break the puller but I've already tried pb-blaster and a hammer. If it has not popped by tomorrow I will have to try the impact wrench.
