160cc injectors.
160cc injectors.
So I'm wanting to up the injectors on this beast but I'm wondering
#1 how hard is it
#2 do I HAVE to get my chip burnt with new programs just for my truck to run
#3 what supporting mods should I do for the injectors? HPOP?
#4 how much smoke should I expect?
#5 how is my e4od tranny going to like it?
#6 What should I be looking at spending in total? $1500?
#1 how hard is it
#1 how hard is it
#4 how is my e4od tranny going to like it?
#1 how hard is it
#2 No, the truck will run but you will not get the benefit of the new injectors until a reburn.
#3 You should do a T500 hpop but a SD one might work.
#4 a stock e40d will not like the II's.
#5 $1235 at Rosewood for II's.
I think I'm gonna go with just normal stage 1s. I was reading that about 350hp is roughly the limit when it comes to having a semi healthy life for your e4od. I'm on the orig. tranny with 154k miles and it's still very healthy and would rather not have to upgrade to say a suncoast or ATS tranny. Anyone else agree with me on this one? Thinking stage ones, running a 80-140hp tune most of the time. NAPA intake and 4 inch straight pipe with a 3 inch down pipe... Maybe make 300-320. Anyone else agree that I'd be on the safe side?
As long as you don't hotrod around, if you're trans is in good shape it will be fine for a while. I ran that combo for a couple years with no problems and about the same mileage. I still have just stage ones and don't plan on ever going bigger. It runs great as is. I did upgrade my trans and converter last winter, I had felt a converter slip once or twice. Actually the trans was still working fine, but I wanted to upgrade it to help hold the power. With all the supporting mods I have with the stage ones I'm not far from 400 hp now. I haven't been on a dyno, but a truck setup just like mine was and had 384hp and 757tq.
If you tow much imo you are going to want to put an intercooler on and a T500 hpop also. If its just a daily driver it will work fine. You won't get full power out of the ones without a bigger hpop and chip reburn.
DougJ_1997PSD
04-06-2015 08:17 PM
