ECT EOT during higher rpms..
I don't normally drive over 70mph because I like to get the most mpgs. I occasionally punch the pedal to get past people and just because it's sometimes fun to show off the power of these tanks... ok, so on to my point...
I was working in Florida this week and I got out of there rather late on Friday to head home. It was 90 degree ambient temps. I had to drive from Tampa to Walterboro, SC to pick up my four wheeler by 6pm, so I had to speed. I had my truck running 80-82 mph and 2350-2400 rpms for hours at a time. I noticed my temps were 13 degrees separation. ECT 190 and EOT 203. At 87 mph and about 2400 rpms, it crept up to 204. I drove for about 3 hours straight with the EOT at 190 and ECT at 203 running 81mph on the Scangauge II.
I thought, well, it looks like my flushes didn't help and I'll have to report to all the guys on the forums that all my work was for nothing. I was going to be eating crow. Once I reached my destination in Walterboro, I loaded up my 800 lb beast in the bed and hit the highway headed home. I set my cruise at 75 mph and headed out. I was running about 1900-2000 rpms. My temps were ECT 190 and EOT 199 and would fluctuate to 186 and 196 and 188 and 198. When I got closer to home, I dropped the cruise to 70 mph and the temp spread was between 8 and 10 steady.
So my question is:
Is this normal expectation to have 3 degrees in only 10 mph? This is the first time I have kept my engine speed and rpms this high for hours at a time. I'm still sitting at 10 degrees when I perform the normal ECT v EOT highway test, so I guess I'll just monitor it. The other thing I noticed is that my ECT has started to drop. When I originally installed a new thermostat, my ECT was 192, then it dropped to 190...188... and now I'm seeing 186. It's only been about 5000 miles. Anyone else seeing this all the time?
So my question is:
When I hand calculate, I normally run about .5 under that. I haven't done it yet because I need to fill up one more time to get the numbers correctly. If it's like the last 8 or so fill ups, It will be about 17.6-17.8 mpg. That's not bad considering the trip back I was just killing it. ha ha.
So what about my coolant temp showing 186 now when driving 65-75? Colder weather maybe? I wonder if it's weak again?
Well the ECT @ 186 could be playing into it
At those speeds with a Good thermostat my truck would run 6-8*f this time year maybe even touch 10* spread depending on Ambeint temp
Just an Example here
Also lets say you run 85mph and Have spread of Say 15*F if you slow down to say 70MPH and see EOT drop to say 10*f spread then that is also a Sign of the Oil Cooler Cooling the Oil and working Properly
When I had that cut up Oil Cooler in those Pics yesterday or whenever it was My Spread was 25*F at all Times If I pushed it it would hit 30*f Spread And NEVER Cool the Oil until truck was shut Off
That's part of the key to watching the ECT/EOT is how well does the oil cooler respond to load changes.
Josh
Mine does that. During the day, if it's hot outside, I'll see 190* at 65 MPH on flat ground. Then at night when the ambient temps drop, so does my ECT to around 184-186. I'm flushing this weekend, and replacing the thermostat and a doing bunch of other crap.
corey fletcher
09-20-2010 05:57 PM
